Question about Husqvarna Sewing Machines
I have a hard time maintaining my tension. Other than the straight stitch (which sometimes even has a hard time keeping its tension), it is almost impossible to set it right. I have tried switching needles, fabric, tension... but nothing works. Is there an adjustment that can be made?
  • 201 Answers
This is an unusual problem. Unless there is a physical problem with the tension disks which requires a technician to repair it, this should not be happening. While you are having trouble and trying to troubleshoot it, be sure to have the same normal sewing thread in the top and in the bobbin. Once your problem is solved, then you can try other types of thread combinations but you need to have a consistent base to work on for now. Be sure you have a new sharp needle. Be sure you have the bobbin thread "clicked" into that little tension slot at the front of the bobbin case (at about 7 o'clock). You will hear the thread click into the slot. Be sure the upper thread has gone into its tension slots too.
This is the most important thing: have the presser foot UP when you are threading. If you have it down, the tension slots are closed and the thread cannot go down between them.
When I thread my Des1 I pull out about 12 inches of thread off the reel of thread, then I hold onto the thread close to the reel with my right hand and use my left hand to take the thread through the thread path. Hold onto that thread near the reel fairly tightly - you want a bit of pull (tension) on the thread as you go to be sure it seats between the tension discs. Once I reach the thread guide just above the needle I give the thread a little tug (reassurance that the thread has fallen between the tension discs) before letting go with the right hand. Then I thread the needle.
Not knowing what model your Husqvarna is, I cannot tell you much more about your tensions. Most current models have automatic tensioning so if none of the above works, you should presume that there is a mechnical problem and get it fixed. I guess that would be the case for an older non-computerised model too - if it's not working, get it fixed. Most problems with tension can be traced back to the threads (top and bottom) not being in their tension disks properly. Once you can eliminate this as being the cause of your trouble, then it's a trip to the machine doctor I'm afraid.
Posted on Aug 07, 2010
My machine is adding loops under my stitches when I try to stitch a straight stitch, I am trying to machine stitch a quilt top!
Quilting is a bit more finicky than regular sewing. Be sure to ALWAYS RAISE the presser foot when threading the top thread. FWIW, I use a separate bobbin case for FMQ that I have tightened the tension to keep the bobbin thread from coming to the top of the sandwich, but I tend to use a finer thread for quilting so adjusting the bobbin takes care of it. In your case, however, it sounds like the top thread is staying under the fabric. I would try tightening the top tension. Also, install a brand new needle--a top stitch, embroidery, or microtex needle seem to work well for me. Test well on a sandwich made of the same fabric and batting and get it adjusted well before sewing on your quilt. Sometimes sewing speed will affect stitches under the fabric, or even on top.
5 Free Motion Quilting Problems and How to Fix Them
Correcting Sewing Machine Tension for Free Motion Quilting NQC
LOOPS Tension or Speed
https://www.generations-quilt-patterns.com/machine-quilting-thread.html
https://www.generations-quilt-patterns.com/sewing-machine-tension.html
https://www.generations-quilt-patterns.com/machine-quilting-tension-problems.html
Feb 27, 2018 | Sewing Machines
Singer model 2638 puckers fabric when sewing straight stitch. Have to manually keep fabric taut behind needle to get anything accomplished. Why does this occur and how can it be fixed?
If the fabric is puckering when stitching, usually it is because the tension is too tight. You may need to loosen both the top and bobbin tensions.
Another time the problem occurs is when sewing fine fabric (like chiffon). The fabric does not have enough body to lay flat, so it puckers. You can utilize a stabilizer to help give the fabric body (washaway or tearaway stabilizer, or even use light-weight paper such as adding machine tape or even toilet tissue). Sometimes some spray starch is enough to help it lay flat.
How to Prevent Puckering Sewing Machine
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwih76G2yuHNAhVBVWMKHV-1DiEQFgggMAE&url=http%3A%2F%2Fwww.amefird.com%2Fwp-content%2Fuploads%2F2010%2F01%2FMinimizing-Seam-Puckering-2-5-10.pdf&usg=AFQjCNF6q0Pk13ZU4Hb3o3RiAGBbL04l-A&cad=rja
http://www.beaconfabric.com/vindex.html?SelectingtheRightStabilizer.htm
http://www.coatsindustrial.com/en/information-hub/apparel-expertise/seam-puckering
Jul 06, 2016 | Singer Sewing Machines
My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
Nov 29, 2015 | Sewing Machines
How do I get my sewing machine to sew with correct tension and straight stitches?
Over time, internal adjustments and servicing is required, at a sewing centers, service dept.
Take it in, have them look and repair, pay the nominal charge!
you will be glad you did!
Apr 16, 2015 | Sewing Machines
Have a brand new Singer 1507 that keeps jamming the bobbin thread. Have followed threading and winding bobbin instructions closely, but am still having problems with the bobbin thread jamming after 1-2...
I would try adjusting the tension on the machine - this sometimes causes the bobbin thread to jam while sewing. Re thread the entire machine including the top thread. Also it is recommended to use new thread as old thread can ball up after time. If no luck I would call the store you purchased the machine from.
Nov 30, 2010 | Sewing Machines
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
Tension problem using zigzag stitch
Most likely the fabric is too light weight to sustain the thread tension using a wide zig-zag stitch. Tunneling will occur in this case.
Loosening the tension (top & bobbin) could also be beneficial.
Sometimes the machine has a special foot (sometimes called overlock) that will help. However, using something to add more body to the fabric, like a wash-away or tear-away fabric stabilizer to the seam or even adding paper will help limit tunneling. Sometimes heavy starch applied to the seamline before stitching will be helpful.
tunneling when zigzagging Threads Magazine Gatherings Forum Sewing...
zigzag stitch troubleshoot
May 08, 2017 | Kenmore 19233 Computerized Sewing Machine
Stitches won't lock
The first thing is to install a brand new needle, which you've already done. Although you can try the suggestions in the attached, if it continues to be a problem, the most likely problem is the machine's out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
10 reasons for skipped stitches
May 18, 2017 | Sewing Machines
Proper Settings
A good standard tension setting is usually around 4.5.
If you find it to be looping on the bottom, raise your top tension. If it's pulling bobbing thread to the top, lower your top tension.
For straight stitch, your stitch width should be set to zero, although on some machines (and I believe your Baby Lock to be one of them,) the stitch width setting will change your needle position.
Stitch length is simply a matter of preference.
-R
Aug 14, 2008 | Baby Lock Ellure
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
