Question about Pool & Spa
Water is not being pumped from pool - Pool & Spa
  • 8,404 Answers
Replace your faulty impeller or find the air leak and fix it.
Posted on Aug 09, 2010
How to put the filter on the pool
The pool filter and pump are critical pieces of equipment in maintaining good water chemistry and keeping the pool water clean. The pump is the most critical piece because it moves water from the pool through the filter and back to the pool.http://www.aurorapoolsandspas.com/
Jun 05, 2013 | Pool & Spa
I have a waterco titanium pool heater water is pouring out of drain holes in the bottom of unit.I have to keep filling up the pool every other day.what do u think is causing the water to puor out like...
in which area do you live, as if the air temp is colder than the pool water it is evapoartion most likely, Test the water coming out of the heater against the water in the pool, if your pool is salt water and the water coming from the heater has no salt then your pool is not leaking, as the heat pump is like an air conditioner it will produce condensate Water from the air. in steamy weather there will be alot of water. David PoolWerx Brisbane
Mar 09, 2013 | Waterco Baker Hydro 80K Btu Titanium...
Motor is burning hot to touch, causing water in secondary trap/pump strainer to heat up. Also, noticed little to no air pressure in pool jets. What could be causing this issue?
Jason
this sounds as though there is no water going through the strainer into the pool. check the gate valves to make sure you have water going to the pump and that water can get back to the pool.
check and valves or backwash valve on the pool to make sure the filter is open to be able to let the water filter to the pool.
something is stopping the water flowing to the pump or preventing the water to move through the pump into the pool.
Rod
US Parts Center
Feb 05, 2013 | AO Smith Centurion 1081 2 Hp Standard...
Pump will not prime
If pumps don't prime there is a reason:
Enough water in the pool or spa?
Is the o-ring on the lid at the pump pot?
Is the lid tight enough?
Does the pump need to "Pull" water to the pump from the body of water for a great distance or height? If so, then you need to be diligent in getting the water to the pump.
Or the Pump Shaft Seal is worn.
Nov 04, 2012 | Hayward 2HP Pool Pump Motor A O Smith...
Pool pump running low psi
your pump should be just fine once the water starts flowing again. You may have run it too long without enough water to cool the seal.
If it is leaking water between the Jacuzzi Pump housing and the motor then you will need a new pump seal. Those are common pool parts.
Rod
US Parts Center
888-521-6183
Jun 09, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
The baxters, the gillberts, and the Sings are pumping water into the swimming pool in their city park. The pool will hold 302000 gallons of water. These neighbors are using their garden hoses to fill up...
Do the families have the proper permits to add water to the public pool? If not should the time to acquire the permits be considered ?
Secondly, What is the temperature of the water coming out of the hoses, as cooler water will expand and fill the pool faster.
Considering all of the unknowns we can not solve for Time. Do you know how much water the Baxters are delivering to the pool? It appears they did not pay their Water bill.
Pool=302,000
Gilberts=G=(B/12)*92/H
Baxters=B
Sings=S=85gallons/H
Time=302,000/S+B+G/H
May 26, 2017 | Learning Company, Inc. Clue Finders Math...
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
