Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I do have a john deere mower js63. It does starts and turns off suddenly. What can I do?
5 Suggested Answers
  • 66 Answers
SOURCE: My John Deer L120 riding mower is shutting down
Two things to consider....fire and fuel. Lets start with the simplest....check and replace the fuel filter, drop bowl off the bottom of carb to make sure float is working properly. If this dosen't work...your looking at a new coil. Some coils will go quickly where others are gradual. As they heat up...they will stop working until allowed to cool down again. www.nnyparts.com
Posted on May 30, 2010
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
  • 760 Answers
SOURCE: i have a john deere js63 walk behind and the self
See this link and follow directions for servicing drive belt. Scroll down to section for your JS63
http://manuals.deere.com/cceomview/OMGC00397_B0/Output/GC00397B08.html
Posted on Jul 26, 2010
  • 2418 Answers
SOURCE: replace drive belt on John
Remove the black plastic cover at the rear of the mower. Here you will find the belt and transmission/pulleys. Remove the cutting blade, (please render the mower unable to start buy removing the spark plug). The belt will pull over the blade shaft and run to the trans. pulley. re-assemble and go cut some grass. But wait until its cooler outside. Hope this helps Fix ya up.
Posted on Jun 16, 2011
Spark plug gap on 8hp
20 thou or .51mm
Specifications - John Deere
manuals.deere.com/cceomview/OMGX21222_J2/Output/OMGX21222_J212.html
  1. Cached
  2. Similar
Model Series 121602, Intek. Horsepower 5 kW ... Spark Plug John Deere M78543, Champion RC12YC. Spark Plug Gap 0.51 mm (0.02 in.) ... JS63 and JS63C. John deer model 63 Google Search
Oct 10, 2016 | Garden
Mower blades move but no gears forward or back, very suddenly quit.
Rex, check the drive belt,old stretched, loose, broke, fell out of position Tension er weak or seized if equipped, worn out pulleys.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tightening the belt on John Deere L110 Tractor
https://jdagccc.custhelp.com/app/answers/detail/a_id/428/~/mower-belt-comes-off---100-series
How to Adjust John Deere Drive Belt
John Deere Fail LA145
Apr 23, 2016 | John Deere L100 Series
Js63 motor quits after a few cuts,ive changed the plug,gas.and air filter still doesnt start now
check for spark by holding a screw driver in the plug wire and holding it about 1/4'' from metal while someone pulls the rope for you a bad coil will cause a no start
Aug 13, 2012 | John Deere Garden
John Deere JS63 problems
Take the starter assembly apart (get the manual - Google it - they're free) and rebuild. Lube, W-40, whatever is sticking. Replace the primer bulb.
Oct 05, 2017 | Garden
John Deere starting problems
check to see if you loose spark when this happens the coil could be failing
May 10, 2012 | John Deere Garden
I have John Deere JS63 self propelled lawn mover. It runs rough and loses power. I cannot mow a ful strip of the lawn as it stall. It is extremely nderpowered. It also runs a little rough when idling...
Have the valves adjusted for they are required to be adjusted every year refering by the owners manual. If the lash or gap is too big this will cause the symptoms your having. Also replacing the spark splug and changing the oil is recomended every year too
Jan 16, 2011 | John Deere Garden
John deere 316 won't start
not sure but i think check the battery i am fighting the same problem and i jumped it from my truck and it runs fine i am looking for a battery tto dya
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
87 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
