Question about Westinghouse LTV-32w3 HD Television
32 inch lcd flat panel tv has no picture but i do have sound. could this be the video driver board or the main controller board? if so, how much does the piece cost to purchase
  • 11,361 Answers
It can be dead 24vdc power supply or shorted out backlight inverter board or dead T-CON board.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 07, 2010
After a thunder storm i have sound, no picture, the tv powers up, the back lights are on, should i suspect a bad lcd screen?
Something else is going on. The T-Con board has no other function than controlling the picture. If there is a separate board for the led drivers, I'd suspect that one. The main board controls the sound.
Mar 11, 2016 | Samsung UN60D6000 60 Inch 1080p Smart TV...
What is the purpose of tickon board in samsung 32
T-con board takes the serial video data from the main board and converts it to a format that the LCD panel will understand. The T-con also supplies power to the panel.
Aug 28, 2013 | Vizio 42 in. LCD TV
Samsung lcd 32 inch tv has vertical lines in color about 4 inches wide all over the screen and it has no picture but it has audio
Only boards are sold and no parts- a 32 inch may not have even the boards or be cost effective to repair----suspect main board here.
Aug 26, 2012 | LG 42LC2D 42 in. LCD HDTV
Ihave a 32 inch flat screen Westinghouse tv that comes on with picture for 8 seconds then goes blank. I still have sound....can you help?
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 21, 2010 | Westinghouse LTV-37w2 HDTV
My Emerson HDTV 32 inch sound stopped working all together. The picture is fine, but there's no sound.
everything with sound picture av component has to do with the main board of the tv not the power supply the only thing you can do its replace the main board not the power supply board or anything else cause it may be only a resistor or a capacitor but to replace it the guy that comes to do it will charge more than replacing it go to www.shopjimmy.com and check your tv model and it will give you what you need and the price and cheaper than the manufacturer
Apr 13, 2010 | Emerson LC320EM9 32 in. LCD HDTV
LG LCD TV/DVD - I have full picture and sound with
is a mute function enable or a defective control board. Needs to be checked. send to repair store.
Jan 16, 2010 | LG 42LB1DRA 42 in. LCD Television
No picture at all. had no problems until last night, turned TV on, and no picture. TV is VIZIO 32 inch LCD
Do you still get sound? If you do get sound, then the problem can be in the backlight inverter board or in the main power supply that supply 24vdc to the inverter board.
Oct 30, 2009 | Vizio L32 32 in. LCD HDTV
Cant get picture when hooking a video player to my 37 inch protro
Hi!
First I would rule out the power supply, a quick way to do this is to visually look for any bad caps (Capacitors), that are bulging on top and or leaky (brownish stain). I would say you need a new signal board as this processes the video to the lcd controller. This can fail, an yet still pass the audio! Now this may be part of the main board, in which case you would need this!!
Feb 16, 2009 | Protron PLTV-32 Television
Televison & Video Logo
112 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
