I just plugged in a cruzer 2.0 flash drive gb 8 and am not being prompted to get it going. I am on firefox
    Master:
  • 344 Answers
Assuming you have windows, you might just have the 'auto-loading' feature turned off.. hit the start button and goto 'my computer'.. if it doesn't show in the drives listing then you either have a faulty flash drive or the usb port isn't working.
Posted on Aug 07, 2010
Formating
Plug the USB into a computer. Find the drive, right-click (or control-click on Mac) and choose format. Folow the prompts.
Apr 13, 2014 | SanDisk Cruzer Glide - USB flash drive -...
I have a kingston 8gb pendrive i had tried to make a bootable pendrive by using command prompt and i failed. I also made my pendrive partition so capacity of my pendrive falled from from 8 gb to 3.44 gb. I...
Most of the time running a disk check first will fix your problem.
Right click on your drive's icon in "My computer"
Select properties. Go to the "tools" tab, select "check for errors".
Depending on the operating system you use, this could also be called "run scan disk", "run disk check" or "check for errors".
Jan 25, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My cruzer 1.o gb flash drive when pluged into the computer doesnt load and the light doesn't even *** on
Looks like the flash drive is dead. Try plugging into a different USB port and also a different computer. IF all these didn't work, the drive is dead. Thanks.
Nov 04, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can I password protect my Cruzer USB 2.0 Flash Drive, 4 GB for in the case I loose it?
The Cuzer has its own encryption software. Plug the Cruzer in a USB 2.0 prt on the computer. If the Cruzer LaunchPad does not execute by default, use the Windows explorer to explore My computer. You will see two icons related to your cruzer, one of them is a CD_ROM. In fact it is the LaunchPad of the U3Smart OS that come swith the Cruzer.
Click on the CD-ROM icon and an a yellow icon (U3) installs on the system tray. Click on it. A pop-up window deploys. Click the Settings button on the right side (2nd menu on the right, under explore drive). You will have to configure U3 LaunchPad Settings. Select Security and enable security.
You will be prompted for a password.
Warning: If you use the Cruzer on Macs or Linux, you will not be able to open it on these OS's if security is enabled. You will be able to open it on Windows only.
Hope it helps.
Thank you for using FixYa.
Nov 18, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I cannot use my Cruzer 8 GB micro. tried fromatting but cannot complete a format. Just cannot access it. I use XP Pro
1. right click on my computer then manage
2. click on disk management then right click on the drive which you want to format then click format it will forcely format your card.
Oct 13, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a sandisk cruzer, led continuously lights
I"ve seen a couple of these do this and the flash disc is broken and not working. Probably nothing you can do to fix it.
Sep 30, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk tutorial
This is hard to find unless someone and lend you one...you can get one from e-bay cheep for less than $8...I do not why you need manual for it just it should be plug and play it mean that you just put it in USB slot and go to your start computer and you should be able to see it as flash drive and use it as you like to move files or store files, etc…let me how it turns out
Sep 14, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
1gb cruzer micro
This is caused by 1 of 2 problems:
  1. Your flash drive is corrupted in some way, forcing the computer to reformat it before you can use it.
  2. The flash drive was formatted for a specific device (like a piano) and was made only for that device.
  3. Your PC incorrectly recognized it
  4. You do not have the correct drivers installed.
If you have problem #4, you can go onto google and search "1 gb cruzer micro drivers".
If you have problem #3, try plugging your flash drive into a different USB port.
If you have problem #2 or #1 (Which it most likely is), then you should try or buy a software application such as PC Inspector, to recover those files. Then you may reformat the flash drive.
However, I found that sometimes, just restarting the computer, and inserting and re-inserting the flash drive sometimes does work. But that's not guaranteed.
Feb 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
