Symbol P460 Scanners need ROM flash: I bought used P460 scanners from a liquidator on eBay. They need to be flashed with the original factory firmware to restore complete functionality. Setting Default App through the System Menu does not restore complete functionality. These scanners must have had custom apps on them that disabled some things. Anybody know how I can restore original factory ROMs? Do I need to download ROMs somewhere? If so, where? And how do I use the ROMs once I have them? I don't know exactly how to do all this, so please be as specific as possible. Thanks much.
  • timstark_mau Aug 07, 2010
    Thanks for the info Steve. I have looked on the Motorola Support page and been reading the Product Reference Guides as well. Unfortunately, there isn't any information in either of these resources that allows me to install the original factory firmware on these Symbol P460 barcode scanners.
    I'm guessing that they need to be flashed with the original ROMs. Right now they can scan any barcodes EXCEPT for the Setup barcodes in the Product Reference Guide. This is presumably because the prior owners of the scanners did not want someone changing their application. Also, after batch scanning, the scanners cannot upload their data to the host PC (Excel, notepad, etc.). Presumably this has also been disabled. Hence the need to return to the original factory firmware.
    Thanks.
  • timstark_mau Aug 09, 2010
    Thanks for your reply Jay. I was unable to find any firmware at all for the Symbol P460 on Motorola's site. There is a 123Scan application but that is unusable by these scanners currently as 123Scan requires you to be able to scan the P460 Setup barcodes. The Setup barcodes are currently not scannable until I can get the original factory firmware flashed back onto these scanners. Please advise if you know of a specific location on Motorola's site that has firmware and instructions for flashing these P460s. Thanks much.
  • 61 Answers
You have to press in order:
1. func
2. *
after 3 beeps
1. func
2. BK
A set up menu should appear, Browse the menu to reset the app to default
Good luck
Posted on Apr 27, 2018
  • 3,866 Answers
According to motorola once these guys where Jailborken so to speak whats done is done!
Now there is a scanner configuration utility
http://support.symbol.com/support/browse.do?WidgetName=BROWSE_PRODUCT&TaxoName=SG_SupportGoals&BROWSE_PRODUCT.isProductTaxonomy=true&BROWSE_PRODUCT.NodeId=SG_P460_1_2&BROWSE_PRODUCT.thisPageUrl=%2Fproduct%2Fproducts.do&id=m4&BROWSE_PRODUCT.TaxoName=SG_SupportGoals&NodeType=leaf&NodeName=P460&BROWSE_PRODUCT.NodeType=leaf&NodeId=SG_P460_1_2&AppContext=AC_ProductPage&param_document=sp
This should allow the scanner to be reconfigured, Part of why this ebay seller was selling these is what your looking for. Most companys write there own apps and firmware for these scanners and once they been flashed or firmwared there is no going back this is according to the manufacture of this device witch was made in 2004.
Now if your company has a set of nice programmers you can rewire a update. But in saying rewirte a update that is out of my scope of expertise. But trying to redownload a rom file and reset this back to orginal will fail and since motorola doesn ot put this file out to attempt it it will be hard for anyone to get.
I sure hope the seller was not loading you with the idea that you can reflash these, let me know
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 09, 2010
    Thanks for the help Rulds. Unfortunately, I can't get that 123Scan configuration utility to work since it requires the scanning of a "Load 123Scan app" barcode. No configuration barcodes from Motorola are scannable. This is one of the problems actually. I'm guessing I just need to send them back to Motorola to have them re-install original factory firmware. That's what Motorola Tech Support said. I was just trying to come up with a faster solution on this site because I'm trying to avoid the turnaround time cost of getting these fixed. Thanks much.
  • 857 Answers
As far as firmware is concerned you can download it from the manufacturers website and instal it. That should help you. To download the firmware visit the manufacturers website go to upport and then drivers and downloads and from there download the firmware must ust the correct model no.
Posted on Aug 07, 2010
  • 1,675 Answers
  • 1 more comment
  • steve morris
    steve morris Aug 07, 2010
    hi tim did you read this bit? it may be of interest to you...as follows
    The Phaser P470/P370 RF scanner is shipped from the factory with a pre-installed default
    application. This fully functional application allows the scanner to be used “out of the box”.
    If you need to load your own application into the scanner, the “Automatic Project Download”
    feature will simplify the process.
    When the default application is running, and the scanner is placed into its paired cradle, the
    scanner will query the MCL-Link host for data in a file named “PHASER.CFG”. The scanner
    will use the information in this file to find the project directory which the user wishes to have
    loaded into the scanner, and will then execute the PROJECT.CMD” script which exists in
    the directory. This script will automatically download all program and data files relevant to
    the project to the scanner and will reset the scanner making it ready to run the user’s
    application.
    In order to utilize this mechanism, the user needs only generate the PHASER.CFG file and
    place it in the directory specified in the MCL-Link setup screen as the “General path for data
    files”. Any text editor may be used to create this file; the contents of the file are as follows:
    X|
    The X| at the beginning of the line are required for the MCL-Net CR command to recognize
    this file and read the data. The path name should include the entire path hierarchy. Also, all
    backslashes (\) in the path name should be replaced with the string “\5C”, so that the MCL
    code running on the scanner does not inadvertently convert part of the path name to the
    equivalent Hex Character.
    An example PHASER.CFG file is shown below:
    x|c:\5Cmcl-p460\5Cdesigner\5Csample1.prj
    is this any use?
    Hi Steve, this is good info. Thanks for that.
    But it seems I don't actually have an "MCL-Link host" and I don't have a "PHASER.CFG" file on my PC. If it is on the scanner, I don't know how to locate it. I have done no software installs on the PC and communication with the host of any sort seems to have been disabled. I see "SCAN: ^----------------------------------" when I start up the guns with * and I can then scan most any barcodes, except for P460 Setup barcodes. But 1, which attempts to upload files to the host always fails and give an option to "Retry" which also fails repeatedly.
    The synapse and USB cables are all new connecting to the host are all new and I have 4 P460s I bought from the liquidator which are all exhibiting the exact same lack of cooperation with regard to uploads. The 123scan utility is also of no use at the moment because it requires the scanning of a Setup barcode to travel down that path. This is rather like being in a canoe without a paddle. lol.
  • steve morris
    yer it seems that way lol, i think what this is telling you is that, the file that is required for the upload and change of software is not located on your pc, i think that you have to make a file, with your information in it for it to upload from the specific location, say, like downloading a file to your hard drive and pointing it in the direction you want it to go, example, C:\mydocuments\downloads, that sort of thing, but as it explains these have to be in a certain format or file format for it to actually gain the information, what it seems to me you need is not to actually flash it back to factory settings by default ( as really there isn't a default as such, Factory is what they are requested to come out of set up ) but to actually flash it to the settings that you need, if you see what i mean, the file specific is installed on your system for this will be the same extension as it says on the other bit i added for you...phewww lol, sorry i couldn't be much more help to you, but it looks like you may have to install to the scanner a file specific for your needs? maybe?..lol
Motorola MC7596 - Windows 6.1 German - PYCSUZWG9WR - I Need a factory Reset for it.
Contact Zebra Technologies or Motorola Solutions for assistance.
Mark
Motorola Mobility Support
Dec 20, 2014 | Zebra Symbol MC75 Portable Data Collector...
How can I remove 3rd party software from my mc9090? When it starts up it goes into windows but then instantly loads the old warehouse software it was originally used for. Is there anyway back out to...
hi try re-flashing the unit, do a search on google for MC909X os update look for the links to motorola support site. you should find all you need there. word of warning only flash the unit with the correct version of windows or you could be in trouble. also you can connect the unit to active sync though the cradle and remove all the files in startup folders. and look for the application that is starting and delete it. what application is it? if its wavelink try exit passwords: leave symbol system one of the above normaly works.
cheers
Jul 17, 2011 | Zebra Symbol Technologies MC909X-G Series...
I am trying to take a program that is on a P460 scanner and put it on another p460 scanner. How do I copy it over?
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Symbol P460 Handheld Barcode Scanner
How to clear all my frequencies from my portable scanner
To clear all information that you've programmed into the scanner you can perform a RESET to original factory settings:
1. Turn off the scanner.
2. While holding down the 2 and 9 keys, turn on the
scanner. CLEAR flashes for about 5 seconds as
the scanner clears its memory.
Note: Do not turn off the scanner again until CLEAR
stops flashing. Otherwise, the scanner might not clear its memory properly.
Bill B
Apr 03, 2010 | Radio Shack Pro-94 Scanner
MC9060 RESET
press the power button for at least 30 this will cold boot your device and set to default.. if for some reason the TARGET application or settings still there what you need is use active sync to remove the REGSAVE from application or some kind of Template that Target has installed onto device....
thanks
Oct 17, 2008 | Symbol MC9060
Computers & Internet Logo
565 people viewed this question
Alun Cox
David Payne
David Payne
