AKAI 32" LCD TV/DVD Player Combo-LCT3201AD. 18 months old. Last few weeks it was taking anywhere from 5 to 20 attempts to turn on.It will not turn on at all now,green light then red. Have tryed to switch outlets ect. What to do?
  • rnavbch Apr 27, 2008
    don' follow
    President:
  • 2,712 Answers
Hello rnavbch,
This is most likely due to 2 problems -Temperature or a bust capacitor,
1. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use hairdryer., but don't hold the dryer too close(say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Reseting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
2. You can also try this..if you unplug the TV, and hold in the power button while plugging it back in, this will reset the TV, and sometimes it comes on.
3. If you want to go in for a long term solution, you can easily replace the whole power board (should be about $20 or so), or just change the faulty capacitors. You can make out which are faulty, because their caps will be swollen on top. Here's a pic
AKAI 32" LCD TV/DVD Player - 017809a.jpg
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you.
PS. The capacitors are usually 680 - 1000 micro farad and 35V. however, if you dont find 35V, you could use a 50V as well. They will be slightly larger, but you should be able to get them to fit in.
You can buy the capacitors online from HERE or HERE if you wish..They cost $0.068 - $0.85 each, depending upon the model.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 27, 2008
  • 4 more comments
  • Swilin Sampson
    Swilin Sampson Apr 27, 2008
    hi,
    just try the hairdryer trick AND the hard reset (points 1 and 2). If you are not sure about about how to replace the capacitors, its ok. Get a technician to do it. If your TV is under warranty, then it is best to take it back to the shop you bought it from.
  • Swilin Sampson
    Hair dryer trick.
    1. Unplug TV from power socket.
    2. Use a hair dryer in full heat near the back of the TV to warm it up.
    3. Hold the hair dryer about 5-6 inches away from the holes at the back of the TV.
    3. Put high heat and warm the back of TV for about 10 mins.
    Hard reset:
    2. Press the Power button on TV.
    3. Plug the TV back into power socket while keeping the power button pressed.
    Hope that helps.
  • Swilin Sampson
    Swilin Sampson Apr 28, 2008
    Just checking to see if your issue has been
    resolved…
  • Swilin Sampson
    Swilin Sampson Apr 29, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything else
    I can assist you with...
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Apr 30, 2008
    Just checking to see if your issue has been resolved…If it has,
    please take a moment to close this problem ticket with a FixYa! rating. I would
    be very grateful for your gesture of appreciation.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    post them here.
    Cheers!
    IrishDruid
  • 813 Answers
Hi fiend
ur dvd player lanse has been week so change it & your problem will solves
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
My akai tv/dvd combo wont turn on?
Hi Nikki,
is there any standby light that comes on at all??
If there isnt than maybe just a blown fuse. replace fuse with the same rating and try again.
thanks,
G..
Nov 04, 2011 | Akai LCT3201AD 32 in. LCD Television
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
Akai 32" wide-screen lcd tv/dvd
Tramaine, I would suggest a new PSU. I have used ShopJimmy.com in the past with great success. Here is a link to the part you need on their site. Hope that helps! TeeVeeMan2
http://www.shopjimmy.com/megmeet-mlt168a-power-supply-unit.htm
Aug 18, 2011 | Akai LCT3201AD 32 in. LCD Television
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
Television will not turn on with remote or from the tv itself. The red light is on, so it is getting power and we have tried other plugs, so outlet is not the problem. Akai 32" LCD TV/DVD Player Combo...
there are capacitors on the power supply that will be vented or the top bulged out
those will need to be repalced to correct the problem
1000mfd 16volt caps
Oct 24, 2009 | Akai LCT3201TD 32 in. LCD Television
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
AKAI WONT POWER ON!
The power supply on your LCD failed and will need to be replace or repair.
Let me know if you need further assistance.
Aug 28, 2008 | Akai LCT3201AD 32 in. LCD Television
Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Sep 09, 2007 | Akai LCT3201AD 32 in. LCD Television
See my other support issue regarding a simillar problem: http://www.fixya.com/support/t155367-red_line Since this is a row of dead pixels and the TV is under warranty, you need to either contact the manufacturer or even exchange it at the retailer you purchased it from.
Jun 22, 2007 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
