My Vizio VMM26F20I unit powers on, however, the display turns black after a second.IDK what to do?
In my case, problem was C504 (12pF, 3KV) on power board. Obviously damaged and discolored. The symptom was the same, initially powers on, then goes black. This cap is in the high voltage supply for the florescent back light lamp. Hardest part is separating the back case to access the power supply located in a metal shroud and taped to the LCD display backlight. No secret, just pry carefully starting at the two slots on the bottom and working around, takes a lot of effort and multiple flat blade screw drivers to work around. Once removed, carefully untape the tape at the corners of the power supply metal shroud. There are two metal shrouds, the one with four small connectors on one side with wires going to the back light is the power supply. Once loose, carefully remove the 4 connectors from the board. Then remove the 5 screws mounting the board to the metal can shroud. Then the board can be lifted to allow access to the power connector, which should be disconnected. Do not attempt to remove the connector with many wires (one red and many black), rather loosen the cable from the shroud bent metal restraining features. Now you can easily access the faulty cap, C504. Replace cap using standard desoldering and soldering principles. Assembly is in reverse order. Good luck!
Posted on Dec 21, 2010
Vizio 55" M550NV turns on, screen displays Vizio symbol for a few seconds then turns black but the tv stays on. What is this and how can I fix it?!
Hi Tiffany, The link below is a YouTube video showing how to fix a Vizio television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
Vizio Tv With No Picture Good Sound YouTube
May 07, 2016 | Vizio Televison & Video
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
The Service Menu will be displayed.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Dec 09, 2010 | Vizio Televison & Video
I have a Vizio (Model #:LP2626, Model Name:VMM26F20I) and I know the power supply board is the problem. However, I cannot find anything on the board with any sort of identifying part number. I've...
Well,Vizparts show the picture of the power supply board wright?Take ur tv aparts,take out the power supply board and compair the power supply board on the picture to ur real actual board.Try Ebay.com another website u can tries.
Oct 27, 2010 | Vizio VA26L 26 in. LCD HDTV
Vizio pop of death, no pic no sound just black screen,
You may need to use the actual plug this time. Unplug the unit from the wall and wait at least 90 seconds to replug it in.
Jul 27, 2010 | Vizio L32 32 in. LCD HDTV
37 inch vizio has black screen. the vizio display
L37HDTV10A THE TV ON NO VIDEO NO MENU SAON OKEY
Jan 16, 2010 | Vizio L37 Television
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
Televison & Video Logo
956 people viewed this question
Top Televison & Video Experts
