Actiontec Wireless Router not providing internet connection
The only way we can access the internet is by plugging the internet cable directly from the modum into the computer
  • 813 Answers
Hi firend
there thats the way but if u have wireless connetion in your router & if u have wireless in your laptop then u can use easy in your home
Posted on Apr 27, 2008
I have an GT704-WG Rev B; Firmware= 30.17.0 which is connected to my (Macintosh) iMac running OS 10.6.7. Until about 6 months ago my older laptop (Mac, iBook, PowerPC purchased in 2001) was able to use...
Turn the Verizon router off.
Turn the ActionTec router off.
Turn the Verizon router on, and wait until its pattern of lights settles-down to a steady pattern, i.e., fully rebooted.
Turn the ActionTec router on.
Turn the ActionTec router on, and wait until its pattern of lights settles-down to a steady pattern, i.e., fully rebooted.
Use an Ethernet cable to connect from one of the LAN ports on the ActionTec router to the network port on your iMac.
You should now have Internet access.
The next step is to start Safari on the Mac, and connect to the web-server "inside" the ActionTec router, e.g., try http://192.168.0.1 and http://192.168.1.1 and http://192.168.2.1
Login to the router, and run the Wireless Networking Setup Wizard, to configure the wireless adapter:
* SSID -- the name of your network
* encryption-level, e.g., use 'WPA' or 'WPA2'
* password for your SSID
Once you've done this, any of your wireless devices should be able to connect to that SSID, and gain Internet access.
Mar 28, 2011 | Actiontec (GT704WG) Router
I have an actiontec gt704wg wireless router (from my previous Verizon DSL service)...I now have a Netgear CGD24G wireless router with Brighthouse roadrunner service...I want to connect my actiontec router...
unfortunately, no. You would be better off Ebaying the actiontec and getting a dedicated router- the reason is that the only uplink on the actiontec is the dsl port- not ethernet. Theoretically you could mod the firmware to make the wireless an access point only- but it would still have the achilles heel of needing an uplink.
Mar 21, 2011 | Actiontec GT704WG Wireless Router...
Using the router
First connect your router to computer then access your router as following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page .
Then set WAN settings as your internet service provider settings.
Enable DHCP.
Go to wireless enable wireless.
SEt wep security if you want secure wi fi.Add WEP code it is your password to connect internet so only who know the password are connect to your wi fi .
Then save settings and restart router.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | Actiontec GT704WG Wireless Router...
My Actiontec wireless router is not transmitting.
hi bob,,.
     Ur prob s coz of incomplete installation of ur drivers,,. install the recomended drivers and access,.  it will,,.
Mar 16, 2009 | Actiontec Computers & Internet
Unable to Access GT704WG Router with Laptop
normally there is a small hole for reset to factory default, just put a pin inside...
Other than that, u can also connect using network cable and access the router configuration, inside, u can edit the wireless security keys
Feb 27, 2009 | Actiontec (GT704WG) Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Red internet light stays on
the following link provides some very streightforward advise;
http://www.qwest.com/internethelp/modems/gt701/pdf/13566_GT701_ServiceStatus_031906msl.pdf
check the following in order
1 check that all of the cables are securely plugged in, if you find any loose plug them back in, you may need to powercycle the router afterwards though if the router is subsquently plugged into another unit down the chain power off both units turn them back on turning on the actiontec last.
2 if your ISP requires logon details to be included in your router, double check by viewing your router settings renter them if you are unsure.
3 lastly, have you paid your ISP bill?
Nov 05, 2008 | Actiontec GT701WG Router (actiongt701wg)
Airport has signal
The airport has a wireless signal but its not supplied by your provider. In order to use wireless at the airpport you have to pay their provider too.
Your system can receive and send to the wireless network in the airport but usually when you have connected to their wireless network, once you open a browser (IE or Firefox) it will provide you with a sign up page where they want you to pay typically $9.99 for 24 hours of use of their wireless network, which you sign up for with a credit card.
So you should be able to recieve that page but you can't access the rest of the internet unless you pay them for access.
Sorry
Aug 14, 2008 | Actiontec GT704WG Wireless Router...
INSTALLING ACTIONTEC WIRELESS ROUTER/MODEM
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | Actiontec GT704WG Wireless Router...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
