SOURCE: wirng connecions for 110v pentair pool motor???
Next, as a suggestion. Purchase an Emerson Pool motor. The electrical connection is the same for 110/220 volts. All you have to do is move the switch by the electrical connections and select 110 or 220 volts. They usually come preset on 220 but I would check anyway. Also, don't forget the ground wire (green) and also connecting the bonding wire on the outside of the motor near the plastic cover for wiring. If you don't have bonding I would get it real soon! Hope this helps..
SOURCE: My Pentair legend pool cleaner is not moving
On this automatic pool cleaner, this is usually an easy thing to fix. First, make sure that your filter bag is clean and free of obstructions. Next, take of your head float and shake it. If you can hear water inside, you will need to order a new head float and install it. They are usually inexpensive and easy to replace. Make sure the hose floats are evenly placed and make sure that the cleaner is not getting too much pressure from the return lines.
SOURCE: I have a Pentair letro legend platinum pool
You DO need a booster pump to power these automatic pool cleaners. It will not work without one.
SOURCE: My pentair minimax plus 250 M pool heater won't
For most pool heaters, if they will not start up in the spring, the problem is corrosion in the wiring somewhere... I would remove and clean all wiring connections and then try. The amount of current is very small and so any bit of corrosion can cause the unit not to work.
It all so could the t-stat again, but you would need to check that with an OHM meter. No continuity when the heater should be on will confirm that the t-stat is bad...
heatman101
