Question about Palm Pixi Cell Phone
My palm just stopped working, ended a call and screen went black. Won't charge or even respond to the charger. Don't know what to do...already took battery out and put back in to no avail.
  • 677 Answers
the truth is that you can unlock the phone ,but you can't unlock all phone for free.
The payment sites are very cheap you could try it out and see.
You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider
and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can
get a free unlock code.
Visit the link below if you are interested in buying the unlock code:
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
Posted on Aug 07, 2010
The phone won't take a charge. The red light comes on indicating that it is charging but it doesn't. What's the deal?
Try this.. as it works for me on my GzOne Rock..
Connect to the charger just long enough for the screen to power on, then immediately disconnect the charger before it goes into charging mode. . -- It should power up and be ready for use.in a couple seconds.
I have found that only when the battery gets completely drained, that the Gzone Rock often will not power back up on it's own, even though the battery has been successfully recharged.
By connecting the to the charger it will initiate the boot-up of the phone - but you must remove it before it displays the charging screen again, otherwise it still won't come on and boot.
I don't know why, but this method works for my GzOne Rock every time.
Jan 31, 2011 | Casio G'zOne Rock Cell Phone
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Hard reset and charging problems
do the hard reset again .. hold the power button down while operating the reset in the back .. keep the power button down for a few seconds .. that should bring up a display "delete all" .. you can choose to do so .. that will be a hard reset .. now if the battery is dead and the charger is not working then nothing will work for you .. you might have a bad charger .. often the end that plugs into the unit develops a broken wire inside the cable ..
the m515 wont charge from the sync cable (shame) it needs the external power adapter .. make sure the connections on the charger and palm are clean .. the power adapter is 5 volts and i think about 1 amp .. )(center pos) if you want to try another adapter .. the tip is rather standard ... also you can get a universal power adapter from radio shack that will work on just about anything .. you just plug in a suitable tip .. the tip for your palm is an "A19" .. the power adapter is "IGO" wall adapter 23-1401 model PSM08VADJ ... that seems to work nicely and it plugs directly in to the palm .. so you can work with it plugged in .. when the charger is working there should be a lightning bolt thru the battery symbol .. it sounds like you already know that .. if the battery has gone open then it may not indicate a charge .. but the unit should still work while on the charger if that is actually working ....
Apr 13, 2009 | Palm m515 Handheld
Palm TX is dead
give it aq reset its in the back there is a mall hole puch it with the stylet
rate me !!!
Aug 16, 2008 | Palm TX Handheld
Palm TX not turn on
It may be a faulty charger. You may have checked this already, but here is the link to the palm website http://us.store.gc.palm.com/?cp=TX&i=1&t1=Chargers%2C+Cables+%26+Cradles&u1=cp&u2=t1
I have a palm TX as well I just hope its a bad charger and not the TX. Sometimes I my TX dosnt charge from the usb sync cable.
Mar 27, 2008 | Palm TX Handheld
Palm treo 600
I have the same problem.  I thought that I might just have a bad charger so I went out and purchased a new one, but it still didn't work.  I noticed that one of the pins inside of the phone had bent against the side of the case. I'm still not sure about what to do.  This might be your problem too.
Oct 15, 2007 | Palm Treo 600 Handheld
Water damage; time for the graveyard?
I think the cost of a mobo and battery would end up costing more than a brand new pda.
If you are handy with a soldering iron, check the solder points for the battery and the ac port....don't know if they could have rusted or even lifted because of the water damage.
Aside from that, I wouldn't know what to check. I think it's amazing your pda works at all.
Also, there is a guy by the name of Chris Short...just google him. He does a lot of Palm repairs for reasonable prices, and he has good customer service.
Goodluck.
Aug 04, 2006 | Palm Zire 72 Handheld
Palm Pixi Cell Phone Logo
237 people viewed this question
Top Palm Cell Phones Experts
fhonwizards
wayne chamberlain
Marvin
Marvin
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
