Question about Jensen VM9510 Car DVD Player
Loud switch i noticed that my 9512 has a loud switch on the front display how do you turn this on?
  • 537 Answers
Check your manual for this.
If you dont' have the manual, consult Jensen's web site and find the manual for the VM9510.
Mike
Posted on Apr 27, 2008
Loud thump near front left wheel when turning left
from the left??? passenger or driver side... this maybe a CV boot problem depending on what side you are speaking of. A CV would be the Ujoint for front wheel drives
Jun 05, 2009 | 2000 Mercury Sable
Hf flashing on screen and beeping loud
H/F error is due to :-- No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
TO RESOLVE THE PROBLEM :
Press PAUSE/CANCEL twice to clear the display. globul1a.gif If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
globul1a.gif If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
globul1a.gif Verify there is not a siphon problem globul1a.gif Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) globul1a.gif Check all hoses for possible leaks globul1a.gif Verify pressure switch operation
globul1a.gif Verify flow meter operation globul1a.gif Verify CCU operation
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Want to know how to turn on loud feature.
There is no 'loud' feature on the Jensen VM 9512.
If your talking about the 3 letters 'LOC' that you can see when you are in radio mode, they do not stand for 'loud'. This is a common mistake.
'LOC' stands for 'local'... not 'loud'.
I know this because I own a Jensen VM 9512, and I have actually read the book that came with it.
Apr 14, 2009 | Car Audio & Video
Jenson touch screen head unit is all hooked up properly in a 2001 honda civic if i turn it up to around 25 with loud off and bass down it will shut off for a few seconds and then turn back on and repeat...
the onboard amp in the deck can't keep up and overheats inturn shutting off the speakers , this is common in jensen touchscreens esp the 9412 9512 and the uv 8 best thing to do is buy a 4 channel amp and the problem will be solved sometimes running a bigger constant power wire to the deck will help a little but not much better off buying a 4 ch amp
Aug 12, 2008 | Jensen Car Audio & Video
BUSHNELL INSTRUCTION MANUAL
Hi - You can download the manual from the link underlined in blue below:
78-9512
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 01, 2008 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Problem with oven
replace oven selector switch.
Feb 04, 2007 | Magic Chef 9512 Electric Single Oven
Jensen VM9510 Car DVD Player Logo
61 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
