Question about Garden
I WOULD LIKE TO KNOW COLOR CODE ON WIRING IGNITION SWITCH PLEASE. THANK YOU.
  • 760 Answers
They all are not necessarily the same. What model and brand.
You must have the brand and model number to know this information. Some craftsman and their sister machines are connect as follows: B (battery) Red wire from fuse. G (ground -12V) L-black to reverse switch A2 Black to seat switch A1 blue to fuel shut off solenoid and hour meter M (magneto) grounds out ignition coil and connects to clutch/brake pedal S (start) white connects through clutch/brake pedal and attachment clutch then to solenoid.
The switch functions are: off M+G+A1
Run override B+A!
Rin B+A1 adn L+A2
Start B+S+A1
Posted on Aug 07, 2010
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1984
1985
1986
1987
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness:
1984, 1985:70-1388
1986, 1987:70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1983 Honda Civic This...
1983
Illumination: n/a
Dimmer: n/a
Front Speakers: 5 1/4" Side Panels
Left Front (+) Blue
Rear Speakers 6 1/2" Rear Doors
Left Rear (-) Gray/Black
NOTES: - none -
Metra Brand Wiring Harness: 70-1388
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
How do I wire a tether switch on 1999 700 RMK
You have to put the tether on the incoming hot wire to the ignition. This will kill all power to the ignition. Thus killing the engine. Sorry I can't tell you the color code.
Feb 01, 2015 | Cars & Trucks
Color code
Most newer vehicles (yours included) have a lot more contacts than just the three you are talking about. I have a 2001 dodge grand caravan and it has 13 different wires running to the ignition switch. The point here is that you will have to combine several wires on one contact which may or may not do the same things the original switch does which may lead to all sorts of strange problems with the engine, transmission and all the other accessories on the vehicle. The other problem is since you will have more things running on one contact, your new switch may be overloaded and prematurely fail or even start a fire since some of the main feeder wires to the ignition switch may not be fused small enough to prevent overheating the switch. A factory/OEM switch may be more expensive but in the long run will save way more problems than the cheaper switch will. To specifically answer your question, most over-the-counter vehicle service manuals available at any auto parts store or in some libraries have generic wiring diagrams that should show you which wire would go where.
May 12, 2013 | 2000 Dodge Caravan
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
1980
1981
1982
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
2002 kia spectra color code ignition switch diagram pdf
PART COLOR LOCATION 12 VOLT CONSTANT WHITE/BLACK (+) and WHITE (+) IGNITION SWITCH HARNESS STARTER RED (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 YELLOW (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLUE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 GREEN (+) IGNITION SWITCH HARNESS
Dec 27, 2011 | 2002 Kia Spectra
Wires got cut from factory harness to the factory stereo need to figure out wire color codes
http://www.the12volt.com/installbay/stereodetail/347.html
Should be it.
Sep 24, 2011 | 1998 Buick LeSabre
Need to know how to hot wire ignition.what color wires do i use?
1991 Ford F150
Vehicle Battery Positive Wire (+): Yellow
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Red/Light Green
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): N/A
Vehicle Second Ignition Wire Location: N/A
Vehicle Accessory Wire (+): Gray/Yellow
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): N/A
Vehicle Second Accessory Wire Location: N/A
Automobile Engine Starter Wire (+): Red/Light Blue
Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): N/A
Automobile Second Engine Starter Wire Location: N/A
Factory Anti-Theft System: None
Factory Anti-Theft System Type: None
Car Key Sense Wire (-): Black/Pink
Car Key Sense Wire Location: At Steering Column Harness
Car Neutral Safety Wire (+): N/A
Car Neutral Safety Wire Location: N/A
Car Tachometer Wire (-): Tan/Yellow
Car Tachometer Wire Location: At Ignition Switch Control Module in Driver Fender Well
Car Speed Sense Wire: Gray/Black
Car Speed Sense Wire Location: Pin #3 at PCM Mounted on the Firewall
Car Parking Lights Wire (+): Brown
Car Parking Lights Wire Location: At Headlight Switch or Driver Side Kick Panel
Car Brake Lights Wire (+): Green
Car Brake Lights Wire Location: At Brake Switch Above the Pedal
Car Reverse Lights Wire (+): Black/Pink
Car Reverse Lights Wire Location: At Switch on Transmission
Car Horn Wire (-): Blue
Car Horn Wire Location: At Steering Column Harness
Sorry friend, this is as far as i can go to tel you how to hot wire the ignition. But with the color codes you should be able to figure it out, Good luck and keep me posted.
Jan 23, 2010 | 1991 Ford F150
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
