Question about Coleman Mach III Air Conditioner
Had "So Called" RV repairman work on Coleman 13.5 Roof AC! He said he fxed it first by lubrication then he replaced the "Hardsart" and told me if the fand stopped again to spin it to get it started and said I should just replace the AC. Another Mechanic PooPooed that Idea and ended up removing the "Hardstart" and wiring direct from the Diod! The sytem worked perfectly for a couple of days then the fan shut down again! Leter on I tried it again and after a "Clank" she started again and we turned it on during the day then off at night it would start the next morning and work fine! It os the fan because when it shuts down it just humms. It will not work now just humms!
  • cliffclaus Aug 07, 2010
    I had gone the the question and answer forum and printed several solutions for problems very simular to mine and there was some close to your though not as specific! The city I am located has no RV AC expertise so I guess I will just play it by ear! I am glad I will not have to buy a new Air Coditioner!
  • Coleman Master
  • 6,674 Answers
If the fan is not turning, but just humming, you need to replace the capacitor. If you were to spin the fan by hand (carefully) when it's doing this, it will speed up and run, until next time. The "hardstart" they refer to is for the compressor and it's basically the same idea, only it's added to the compressor start capacitor to assist it. If when the fan does run, your getting cool air, then the compressor start capacitor is probably ok, for now. The capacitors store extra voltage, for start up of fan, as well as compressor. Capacitors are approx $20, and take about 1/2 to change.
Posted on Aug 06, 2010
  • Mike Butler
    Mike Butler Aug 06, 2010
    One thing I forgot to tell you is that capacitors can give a real good "Jolt", (shock) if not handled properly, as they store anywhere from 250-370 volts usually in that application, whether power is turned off or not, so someone experienced should be doing the replacement.
Why is my ac in my RV LEAKING INSIDE FROM THE ROOF?
Ur drainage tube is plugged so look for it and unplug it or change it it's called condensation tube
Jul 23, 2014 | Coleman Heating & Cooling
Coleman RV Roof Type 110v
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 25, 2010 | Coleman Heating & Cooling
13.5 Dometic rooftop rv ac design has changed since I purchased 2006 Monaco Camelot rv. The collection cups leading to the drain line do not fit well on the roof seal and a good seal is hard to achieve. If...
I've not run into the problem your having yet, so I will apologize up front for asking you to furnish more information. These drain cups that I assume are little round pieces attached to the base of the unit where it meets the roof, were not common on dometic, but were common on Coleman AC units. Those are the outlets for condensation to the roof anyway, are they not?
Also, as far as gasket goes, no I wouldn't recommend using 2. We were always advised by manufacturer to compress gasket to half the original thickness when installing either Dometic, or Coleman (RV Products). Coleman at one time, had tabs under gasket that when gasket was compressed, and they touched the roof surface inside, that was far enough, which was approximately half the original thickness. Believe it or not, over-tightening is more likely to cause a leak. Stick with half original thickness, or close to it.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
I have a coleman Mach Air Conditoner on my RV. How do I remove the cover from the unit on the roof of the RV?
GO TO rvcomfort.com
Jun 19, 2010 | Heating & Cooling
We have a Coleman roof unit a/c on our RV. We are going to be replacing it and we're not sure what the btu's are. We are thinking 13,500. The model no. is 6759-707. Can anyone tell us what the btu's are...
GO TO rvcomfort.com
Jun 08, 2010 | Coleman Mach 15 Air Conditioner
I would like to run a coleman rv roof air conditioner Mod # 6727-736 on the bench before installing on the Rv. It is a used unit. The plugin has 6 wires. I wont to see if the compressor is still...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
GO TO
www.rvcomfort.com
May 09, 2009 | Heating & Cooling
We have a rooftop coleman air conditioner on our RV. When it runs it trips water on the counter top instead of draining on the roof. I don't know how to fix it
GO TO rvcomfort.com
Apr 20, 2009 | Coleman Heating & Cooling
Coleman Mach III Air Conditioner Logo
78 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
