Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My toshiba regza is shutting on and off by itself i have to unplug it for it to stop..i really love my tv ...help!!!!
    Master:
  • 344 Answers
Sounds like you might have an infrared emitter somewhere pulsing at the same frequency as your tv for on/off. Try covering the infrared 'eye' on the TV with a piece of foil. if that stops the tv from going on and off then you can take a camera like one you find on a cell phone that can see infrared light and look around the house for whats emitting the signal. easy way to see if the cameras can see infrared light is to turn it on and point it at the end of a remote. when you press buttons on the remote you should see the normally invisible light blinking.
Posted on Aug 06, 2010
Hello, I have an Toshiba REGZA 42" LCD TV, the
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.......
Jun 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Hi,Iwas watching TV and the screen went black.No lights on,I unplugged and plugged again but anything happened. My TV is a Toshiba Regza model 42RV530U. Can you help me? Thanks
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
May 24, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Mar 14, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Tv is flashing a "no
Tries tv and cables or satellites boxes unplug,replug it back again like about an hour later.Tv will be resetting itself back to the factory setting and those boxes will updates it softwares.The tv should be working again.If have the same problems as before.Than the tv have a Tuner signal board problems,call Toshiba for a warrenty repair.
Jan 18, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
Toshiba Regza tv was in storage we took it out and can't find remote is there a way to tune without it? Thanks
Yes,must use the manual control on the tv itself.Very trouble some.Buy a new exact remote on website 1-800-Remotes Factory Original.
Jan 16, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Cant Power up/down. DVD player wont work
You can try leaving the television unpluged for a couple of days and see if letting the circuits completely discharge will let the television reset itself to normal operation. You can also call Toshiba customer support and ask them if this problem is common and if there is a simple solution. The customer service telephone number is 1-800-631-3811. Give them the model number of your television and they will help you. I hope this information help you with your problem.
May 01, 2009 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
170 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
