Question about Boating
Repar water pump on 1996 35hp johnson - Boating
  • 135 Answers
VERY EASY REPLACEMENT
REMOVE PHILIPS HEAD SCREWS THAT HOLDS THE PLASTIC WATER STRAINERS ON THE FOOTOF THE MOTOR,
NEXT LOOSEN THE HEX FITTINGS 7/16 OR 1/2 WRENCH SIZE THAT WERE COVERED BY THE STRAINERS
NEXT REMOVE THE 2 STAINLESS STEEL BOLTS THAT ATTACH THE FOOT TO THE LOWER UNIT.. BOLTS COME OUT FROM THE BOTTOM,, NEXT LOOSEN THE NUT ON THE FRONT OF THE FOOT FACING THE TRANSOM LEAVE A FEW THREADS TO HOLD THE FOOT SO IT DOSEN'T FALL. NEXT WIGGLE AND SHAKE THE FOOT
TO LOOSEN IT FROM THE LOWER UNIT . NEXT STEP REMOVE THE NUT WHILE HOLDING UP ON THE FOOT THEN SLOWLY REMOVE FOOT ASSEMBLY WITH DRIVE SHAFT.
NEXT REMOVE THE O RING FROM THE FITTING THEN REMOVE THE FITTING FROM THE SHIFT ROD THERE SHOULD BE A BIGGER O'RING ON THE SHIFT ROD NEXT TO THE WATER PUMP HOUSING . REMOVE BOLTS HOLDING WATER PUMP HOUSING ON THE FOOT ASSEMBLY LIFT OFF HOUSING LOOK FOR IMPELLER KEY TO FALL OUT . I RECOMMEND REPLACING IMPELLER AND HOUSING AS A KIT . INSTALL IN REVERSE ORDER .
IT'S A PIECE OF CAKE ...
Posted on Aug 06, 2010
How to tune up 15 hp Johnson outboard
For minor tune-up. Remove, clean or replace spark plugs. Use Johnson recommened fuel additive and recommended fuel type. Replace lower unit grease. Spray clean carburetor. Check fuel line and filter. check water pump function.
Oct 14, 2017 | Johnson Boating
1966 johnson 3hp, how to tell if water pump working?
You can unhook tge cooling line while then crank it. Sgould spray water.
Aug 02, 2017 | Johnson Boating
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
My 1970 65 horse Johnson out bored having problems with it running in water but runs good with water hose what could it be
quite possible that your motor needs a water pump. hose flushers force water thru at full pressure where as the pump pushes water only what the pump forces thru
Jul 09, 2014 | Boating
Video on how to replace a water pump for 1993 30hp johnson
One of these videos on YouTube may work for you
http://www.youtube.com/results?search_query=johnson+30hp+outboard+water+pump
Jun 25, 2014 | Boating
Changing impeller on 90hp v4 johnson 2000
Remove Linkage Under Carburetor
Remove Bolts Securing Gear Box Remove Gear Box
Do Not Turn Shift Linkage
Remove Water Pump Housing
Fit New Impeller
Re Fit Gearbox Follow Procedure In Reverse
Mar 16, 2013 | Boating
I have the Johnson Viking Power 16 Waste Pump installed. It says in the manual that it is fully self priming up to something like two or three meters. I have maybe a 70 cm difference between the shower and...
"Does not want to start again". As in the motor does not turn on or as in it doesn't pump the water out?
The lines from the tank to the pump have to be air tight or it will not be able to "draw" the water due to all the air getting in the line. From the pump to outlet, not quite as important except you really don't want water spraying everywhere so should be fairly tight and sealed.
If it is using a float switch to start the motor, make sure it is working properly.
Sep 29, 2012 | Johnson 10-13350-03 Viking Power 16 Waste...
Johnson 6hp outboard engine fuel pump diagram
Here is where you can get a service manual, they have a lot of info you might need...
Johnson Evinrude Manuals 1917 2007
Jun 11, 2012 | Johnson Boating
Small amount of water now left in drain - it was never there prior to a replacment of pump that failed. Is this normal? White powedery residue has now appeared for the first time.
Welcome to FixYa.
This is a common complaint following a drain pump change out, particularly when one has an older Bosch and installing the new style/revised outlet pumps.
If you still have your old pump or if you recall observing it, that design usually only had 4 vanes on the impeller to pump the water.
Since then however, Bosch has re-designed their drain pumps to allow them to be "quieter" hence they now have either a 6 or 9 vane ( depending on model ) on the pump impeller, so yes they are much quieter but as a result pump less water in the time allowed.
example...
...So to answer your question it likely is normal and should be of little consequence. but if you`d like you can still get the other style, you just need to know what to ask for but is quite often "special order". Part # 184178.
NOTE - If you live in the Northwest region of the states ( Especially Washington ) often installation for dishwashers include what is know as a "Johnson Tee" air gaps in the wall.
**Johnson Tees were designed for older dishwashers with 1/2” drain
tubing and work better with stronger 4-vane drain pumps (# 184178) instead of
the current quieter 6-vane pumps (# 167082). In homes with Johnson Tees, use
only 4-vane drain pumps (# 184178).**
Hope that helps, let me know if I can assist you further and good luck.
Thank you for choosing FixYa. Please take a moment to rate the info provided for you here today.
macmarkus :)
Aug 26, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Boating Logo
117 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
