Question about NetGear ProSafe FS726TP Smart Switch switch 24 ports (S4416379)
I have a netgear FS726TP and need to reset the forgotten password
  • 2,296 Answers
You will need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Posted on Feb 11, 2011
Have received a new i pod touch I have forgotten my netgear DG834G password therefore cannot use the new i pod can u help
Do a factory reset hold reset button for 10 secs. Username = admin, Password = password, the default IP is 192.168.0.1
Sep 06, 2011 | NetGear DG834G Router
I need my netgear password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
Reset and Restore the NETGEAR device to Factory Default Settings
Symptoms:
  • Forgotten/lost password to log into the NETGEAR device
  • Cannot access the NETGEAR device web interface
Click here for video walk through example of how to reset the WGR614v9 router.
Resolution:
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
Here is a small video that shows you how:
Good luck.
Mar 10, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
Wont take any passwords
If you have forgotten the login password, you can reset the Netgear back to the default settings by power up the Netgear and press and hold the pinhole RESET button at the back of the router until the LEDs flash.
The default login = admin
the default PW = password
Dec 21, 2010 | NetGear WGR614 Wireless Router
I ahve forgotten my forgotten netgear password on WGR614 router. Please advise Thanks Tony
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Dec 14, 2010 | NetGear WGR614 Router
Default factory password
  • Username = admin
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 | Cell Phones
I am trying to configure a netgear wgt624 v3 router. I can't get passed the admin and password. Please help me configure this
  • Username = admin
Feb 12, 2010 | Computers & Internet
Forgot my password
Most of the NETGEAR devices have the following default username and password except ReadyNAS products and Fully Managed switches:
  • Username is always admin
  • Password is password or (for older devices) 1234
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | NetGear RangeMax WPN824 Router
Cant remember my netgear network key
Reset and Restore the NETGEAR device to Factory Default Settings Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); Symptoms:
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); Resolution:
When a NETGEAR device resets, it goes back to the state when it was new — all information that was entered by hand is lost! Examples are critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
Hope this helps.......
God Bless.......
Aug 26, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Forgotten netgear DG834G wirelles password
Press and hold the reset button on the back of the router for 10 seconds. That will reset the router back to factory defaults
Jul 20, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Netgear fs726tp and cisco phones
that the 7940 and 60
phones from Cisco do not support the IEEE 802.3af Power Over Ethernet
standard
they would work if you
simply reversed the polarity of 2 of the pairs of wire. i.e
by swapping 4 with 7, and 5 with 8 you could use a standard
POE injector to power the phone.
if you have a crimp tool and some cable laying around, you can give it
a whirl and it works. If you aren't familiar with making cable,
don't try this
Basically, you just wire one side of the cable as standard 568b
and then reverse 4 and 7, and 5 and 8 on the other side. Then,
simply plug your Cisco into a standard POE injector and Your phone works.
Nov 16, 2007 | NetGear ProSafe FS726TP Smart Switch...
Open Questions:
Steps To Fix Toshiba Laptop virus and Freezes Issue Call toll free Number :+1888784-9316 Are you facing sudden pop-ups on your computer or witnessing slow loading of files and programs? If you are getting issues like slow internet and processing, unexpected computer behavior then contact Toshiba support for making your computer free from all such dangerous online threats. Toshiba support provides safe and secure removal of all virus and other infections along with protecting the system from any such instances further. Toshiba support providing technicians make sure that your pc is secure and also that all your important files and documents are safe from any type of harm. If your system is infected with viruses, Trojans or malware then it might show signs like slow computer processing and internet speed, unexpected computer behavior, sudden freezing and crashing down of the system, frequent arrival of error messages, many advertisement pop-ups, non-intended outgoing emails and messages to contacts, files disappearing, problems in hardware and accessory devices, screen freezing and image blurring issue etc. Toshiba support helps in scanning all the variants of virus inhibiting the system by using proper scanning process and removal processes after that. Many a times, user while scanning viruses on his system might not be able to remove all even after many attempts. This happens because system gets infected to new variant of virus due to vulnerabilities of programs used in that system or because of inefficient scanning methods. The anti-virus program used for scanning the presence of that virus might not have got that virus's signature. So, for proper and efficient scanning of all viruses and removal afterwards, it is necessary to take help from experts like Toshiba support technicians. These technicians utilize the efficiency of advanced techniques and much better tools to clean the system and make it infection proof in order to yield greater productivity. Specialists of Toshiba support collect samples of all the variants of new and recent viruses and update the user's software database with their signatures. In case your system is also suffering from the infection of any such viruses which is new and is creating trouble getting detected, then contact Toshiba support us for help on their toll-free Toshiba customer helpline number +1888784-9316 anytime for expert supervision and advice.
Aug 14, 2018 | Toshiba Computers & Internet
See all NetGear ProSafe FS726TP Smart Switch switch 24 Questions
NetGear ProSafe FS726TP Smart Switch switch 24 ports (S4416379) Logo
1,681 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
