Question about One For All URC-3300 Remote Control
I want to set my remote on a caira tv and i cant find the codes manual
I have a oneforall brand remote control but i dont know the model number and cant find the 4 digit set up code for my citizen tv
0060, 0030, or 0092 are possibilities, if it is the URC3021. if it is another model remote, look up the remote at http://www.oneforall-int.com/support/manual , enter the model number, and look on the manual for the correct codes for your TV.
Apr 02, 2014 | One For All Televison & Video
Cant set remote to my make of t.v
download the code from www.fitness.manualsonline.com or www.remotecodelist.com
God bless you
Jul 19, 2012 | Televison & Video
Need remote codes
You may be able to get help here. This is a link for the owners manual in PDF.
Hope this helps!
http://dukeelectronic.com/Manual/IWT3206.pdf
May 30, 2009 | iLO IWT3206 TV
Cant find the right remote control codes
look in back of remote where you put battiers there should be a sticker that will say this... turn tv on press and hold set button tell it blinks or stays lit push tv on remote push on and off tell tv shuts off press enter now you should have it
Feb 17, 2009 | GE RM24930 Remote Control
I cant set my universal remote to my magnasonic tv
TV Can Not Be Programmed on this remote. Sorry.
=> http://remotes.com/remotes/documents/RCA/257003.pdf
Dec 24, 2008 | RCA 257003 Remote Control
Remote codes for Haier tv sets
I saw the post above about an association with Hitachi and it worked for me. I have Haier model HL40XP1 and used the Hitachi code 10056.
Jul 15, 2008 | Televison & Video
Universal Remote Woes
Email sent: Most univ remotes provide a method of scanning codes. Example: You set the TV on, select TV on the remote, put it into code scan mode, scan TV codes 1 at a time and when the TV turns off, store the code. This should be in the remote's manual. Hope that helps... Geno
Mar 05, 2008 | Televison & Video
URC22B universal remote controller 15 in 1
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Nov 27, 2007 | Zenith ZN110 Remote Control
Jensen JR500 Remote Volume Control
Try reprogramming the codes into the TV for the volume control.
Jensen JR500 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps! DONT FORGET TO RATE ME on FIXYA!
Sep 04, 2006 | Jensen JR500 Remote Control
One For All URC-3300 Remote Control Logo
170 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
