Question about Dewalt 12V XRP Battery Pack
Put battery on charge it flashes slowly like it is charging then after about 30 seconds it starts flashing very fast, and is not charging battery at all?????
  • 2,176 Answers
Battery is bad and needs to be replaced. But first you might try and clean the contacts.
Posted on Aug 09, 2010
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
My SB600 seldom firing when triggered manually on the red flash button. Only 2 or 3 times flashing after 30 attempt. Tried with new battery but same problem occured. Help.
If you are firing the flash manually it's giving full burst each time and the battery needs to pick up the charge from the bottom. So just numbers her for an example with a full set of batteries you manually flash, first burst takes 5 seconds to charge flash again it'll take 10 seconds, if you flash it again before that 10 seconds it'll now take 20 seconds and if you push that button again it might misfire because it just can't get the power up high enough to fire it. The flash isn't a studio strobe which is plugged into an outlet, you are working with battery power and each time you flash those batteries are under a huge load and each time you fire you kill them a little more I'm surprised you are getting 30 flashes from those batteries. My guess at full power you are going to start having problems after about 12 to 15 flash bursts and it's a rapid down hill drop in performance from then on. If you took those batteries out of the flash after that series of 30 flashes I'll bet they are hot. What you can do to help is set the system up with Nikon's wireless transmitter and utilize the new i-TTL system then you are taking performance.
Jan 07, 2011 | Nikon Speedlight SB-600 TTL Flash
When I put the battery to charge the red LDc flashes as normal but then speeds up and flashes fast. The battery does not charge! any ideas?
the battery is bad, the fast flashing red indicated an internal short in the battery or it is consumed and needs to be replaced.
Nov 19, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Put new ignition in 2003 sunfire. engine wont stay running and theft lock symbol on in dash
HI.
Follow this step to keep running your sunfire.
1 - Be sure the battery is full charged.
2 - Is better if you put a battery charged
3 - Turn the key to run position and tray to start the car and leave with the key in run position,
With a watch let pass 10 minutes no less. you gonna see the security light flashing and stop flashing after 10 munites.
4 - After 10 munites turn the key to off position during 30 seconds, with watch on your hand, OK.
6-- After the 30 seconds try to star the car
I hope this solve your problem.
Please letme know.
Thank you for use fixya.
Jul 11, 2008 | 2003 Pontiac Sunfire
Flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
Help on P72
The recycle time using flash gets worse pretty quickly if you are using the onboard flash. The delay is pretty much inversly proportional to the remaining charge in the battery. I.E. the less charge, the longer the time. This happens with any camera. You might check the time with fresh batteries (or freshly charged) and then after maybe 20 shots or so. I would not find 5 seconds atypical, but 10 seconds sounds like you are pretty close to dead battery. If you get 10 seconds at the start of a fresh battery, then you may have a problem. Also, capacitor charge time can vary from capacitor to capacitor and a 1-2 second variation between camera flash units, either onboard or off board is probably normal. Age of capacitor can also have an effect.
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Dewalt 12V XRP Battery Pack  Logo
151 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
