Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
It won't turn on icheak all cords won't light up are nothing
    Master:
  • 344 Answers
Could be a faulty power supply. have someone check the plug with a volometre to reassure it is functioning properly.
Posted on Aug 06, 2010
How can I fix my hp61 of it won't start screen
You say the battery is charging? Have you tried another Cord/Charger with the EXACT same power specs? Has the AC jack been damaged due to pulling on the cord while plugged in? Any damage? Drop? Do you leave the Laptop plugged in while not in use?
Apr 13, 2013 | Computers & Internet
Frigidaire electeic dryer won't turn on.
Have you checked the door switch to make sure it is closed when the door is closed?
Jan 21, 2013 | Frigidaire Dryers
Toshiba Regza 55zu655u won't turn on no lights
If its total dead with nothing suspect the fuse the power cord goes to inside the set, if other let me know what it is doing or not doing in more detail.
Dec 04, 2012 | Televison & Video
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
My TV won't turn on. It was fine this afternoon and when I tried to put in on tonight, nothing.
The key here is does the red power light come on? If not follow power cord inside to the fuse that is directly in line with the cord.
If other let me know.
Apr 23, 2012 | Hitachi 51F510 51" Rear Projection...
My Juki TL-98Q won't turn on. No hummm, nothing. I've checked all connections and they are fine. Cords are in good shape. It was running beautifully prior to this.
If the light is on but no noise at all when you press on the control it must be a break in the lead at the very least or the brushes on the motor at the worst
Sep 30, 2011 | Juki TL-98Q
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
HP VP6210 won´t turn on at all
try to replace all the capacitors on the motherboard. This are the only parts that leak in time. Try otherwise to reset to counter or update the firmware on your machine on the infocus site.
Goodluck !
Sep 04, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
the fuse (if it has one) is on the power supply next to where the plug plugs in. if the fuse is ok, replace the power supply.
Jul 18, 2008 | Office Equipment & Supplies
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
77 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
