I Have A 32 Inch MAG lcd television. when i turn it on backlights come on and thats it , i get no picture
  • 1 more comment
  • Rey Garza Aug 06, 2010
    after i turn it on it won't power off when i push on/off button . I have to disconnect it
  • Rey Garza Aug 07, 2010
    I Have A 32 Inch MAG lcd television. when i turn it on backlights come on and thats it , i get no picture and when i push on/off button it won't turn off. I checked power supply board and all voltages going out reading like it should.
  • Rey Garza Aug 13, 2010
    thanks
  • 10,515 Answers
There could be many problems associated with the same.The main problems are :-
1. Inverter has developed a problem
2. Powerpack that feeds the inverter has developed a problem
3. Their may be software problems to do with the mainboard
4. The backlight itself is at fault, or connections to the backlight are fragile.
It could be any of the 4 suspects in the list,the favourite is the inverter but it can only be diagnosed with specialist tools,oscilloscope volt meter temperature control solder station specialist semiconductors and passive devices and their is a device available now to check the backlight in situ.
A simple, but not 100% test to verify if it is the inverter, is to shine a flashlight into the darkened screen and see if you see faint images where the light shines - dim or darkened room. If you have some mechanical and electrical knowledge, you should be able to replace it
Good Luck!!
Thanks!!
Posted on Aug 07, 2010
    backlights power on, but i believe the actul screen is not powering up to view any image
  • taran_2005
    taran_2005 Aug 07, 2010
    Thanks for your response!!
    More often on these models, it is a sign of faulty inverter. If you have eliminated all the above factors, then it's definitely LVDS cable and / or T-conn board or as you called it a controller. I am not sure if it is available without the panel.
    Good Luck!!
    Thanks!!
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand.
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual
Above is an LG, similar unit, training manual, this will give you an understanding of how it all goes together and works and how to approach servicing.
Posted on Aug 06, 2010
My westinghouse 32 inch flat panel tv turns on i get the picture then in about 20 seconds picture goes out but still have volume. i turn it off then on again and the same thing happens ....help
This tv have a dead long board call the LCD inverter board.This long LCD inverter board job are to help the LCD screen panel to have a backlight to produced a picture.Replaced this long LCD inverter board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Dec 02, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Samsung 32 inch LE32R73BD 3 yers old, no picture but i have sound
Tv turn on now,have flicker of picture few sec.than dies.Have sound left only?Yes,than the 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Sep 09, 2010 | Televison & Video
Ihave a 32 inch flat screen Westinghouse tv that comes on with picture for 8 seconds then goes blank. I still have sound....can you help?
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 21, 2010 | Westinghouse LTV-37w2 HDTV
No picture at all. had no problems until last night, turned TV on, and no picture. TV is VIZIO 32 inch LCD
Do you still get sound? If you do get sound, then the problem can be in the backlight inverter board or in the main power supply that supply 24vdc to the inverter board.
Oct 30, 2009 | Vizio L32 32 in. LCD HDTV
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have a 32" TV/DVD combo westinghouse LCD TV. When I turn the TV on I get no picture. There is sound. DVD player does not show picture either, I have sound but no picture.
This is a backlight or inverter Problem. Based on the model you have, I am guessing the inverter is defective.
Inverter is defined as the board in the TV that supplies power for the flourescent lights inside the LCD TV that provide backlighting for the TV's Display
Jun 22, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
No picture or sound
Hello guys,
TV intercate light up but no picture or logo; Even when you replace all the caps still not powr up the TV. One of the board is defective that will cost the none communicate with other board that cost this problem. it mean some of the ic is burned. But it might come from the power supply, main board or the backlight went out. You need to bring your tv to the service.
Any question please call me at 323-767-6030 and I will go through with you.
Sep 02, 2008 | Astar LTV-3201 32 in. LCD Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
