Question about Edimax BR-6216Mg Wireless Router (BR6216MG)
How to set up security enabled facility
Cannot set up security enabled setting for the wireless router, please help
  • serra baby
    serra baby May 11, 2010
    hello!
    -- what is the brand and model number of your wireless adapter?
    -- what is the operating system of your computer?
    -- do you know the wireless settings configured on your wireless router?
  • Ella Grace Leynes
    Ella Grace Leynes May 11, 2010
    what is the brand and model number of your router?
    Scholar:
  • 70 Answers
You can try these steps to configure the BR6216MG router for wireless security:
1. connect a computer to the router's numbered port.
2. launch a browser and type in 192.168.2.1, user name is admin and the password is 1234 (unless you changed it, if you do, then use that password)
3. Once you are in, click on wireless then click on Security.
4. Under Security, you can set it to either WEP or WPA. But for ease of use, I suggest you use WEP.
5. Set it to WEP then 64 bit for the key length.
6. You can then select ASCII or hex (that depends if your wireless adapter support both or one only). For hex, you can only use the letters A-F and numbers 0-9. For ascii, you can use characters, letters and numbers.
7. Set the default key. Only the key you select it in the "Default key" will take effect.
8.You can now fill the selected text box with the password that you want. Then click Apply.
If you have questions, just ask me then I'll answer your question as soon as I can.
Posted on May 12, 2008
Well it has no secruity and i can't put it on... How do i do it ?
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure MAC Access Control list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router, you must configure your wireless clients with the matching settings. Your wireless clients will not be able to connect to your network unless you configure matching settings.
  • It is recommended you enable these wireless security settings from a computer wired to the router.
    1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
    2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
    3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
    4. Click Security under Wireless menu.
      1. Under Security, Select 64 bit WEP (or 128 bitWEP).
      2. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
      3. Apply the settings. Please write down the key - You will need it later to configure your wireless computers with the same key.
Mar 30, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How can I find or reset the security key on my D-link WBR-2310 wireless router?
In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
I cant enable the password
Hi Friend,
In order to enable wireless security password, please follow the steps:
1.Type 192.168.1.1 in the address bar of the web browser and hit enter
2.Enter the username and password. If you have not set the router password then leave the username blank and type admin in password and hit enter.
3.Click the tab Wirelss in the setup page and fill the sections
Wireless Network Mode:Mixed
Wireless Network Name:As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enabled and click Save Settings
4.Click Wireless Security and fill the sections as mentoned
Security Mode-WPA Personal
PA Algorith- TKIP
WPA Shared Key-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
You have now set a password to your wireless network and is secured. Enjoy
Regards
Chiranjeet
Sep 16, 2010 | Linksys Wireless-G WRT54G Router
I need to et my user name and logon domain i dont rmember them . i just got my lap top repaired and need to reconnect to my router
Router Login: http://192.168.1.1
Login Name: admin
Login Password: password
>If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port to restore the Router to factory settings.
>Please click on Wireless and click on Security to check the Security key for the Network.
>If the Router is reset to factory settings, then it is required to enable the Wireless feature under Wireless settings and enable the Security key.
Good Luck!!!
Jul 02, 2010 | NetGear WNR2000 Wireless Router
How do I enable wireless security on router
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Jun 25, 2010 | D-Link DIR-615 Wireless Router
Create wireless security
1.Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the URL web address location.
2. When the following dialog box appears, enter the user name and password to login to the main configuration window, the default username and password is “admin”.
3.Setup wizard is provided as part of the web configuration utility. User can simply follow the step-by-step process to get the wireless Router configuration ready to run in 6 easy steps by clicking on` the “Wizard” button on the function menu. The following screen will appear. Please click “Next” to continue.
4.Set Wireless LAN connection
Click “Enable” to enable Wireless LAN. If user enables the Wireless LAN, type the SSID in the text box and select a communications channel. The SSID and channel must be the same as wireless devices attempting to connect to the WLAN Router.
(When in FCC domain, you could chose ch1~ch11; in ETSI domain, you could chose ch1~ch13)
4. Click on Security.
5.Security
This function enables user to set authentication type for secure wireless communications. Open System allows public access to the router via wireless communications. Shared Key requires the user to set a WEP key to exchange data with other wireless clients that have the same WEP key. This router also supports WPA, WPA2 and WPA-PSK, WPA2-PSK.
6.Set the Security key and save the settings.
7. The Wireless is secured now.
You can find more information in the User Guide.
Here is the link: refer page #26,27,33 to get all the info.
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N2_Manual_Cam.pdf
Jun 23, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
Set up a non wep password
Hi Friend,
Please follow the steps;
1.Open the router page(192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.Click Wireless and then fill the sections as mentioned:
Wireless-Enabled
Wireless Netowrk Name-As per your choice
Wireless Channel-6-2.442GHz
Wireless SSID broadcast-Enabled and click Save settings
Wireless Security-Enabled
Security Mode-WPA pres-shared key (as you want non wep password)
WPA Algorithm-TKIP
WPA Shared key-Minimum 8 and maximum 64 digit password
Group Key Renewal-3600 and click save settings
Turn off the router for 30 seconds and turn it on after that. Now you have a non wep secured network
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Zoom Wireless Router
Make sure that your PC wireless security settings are correct, as you will need to input a WEP or WPA key if the router has wireless security enabled. Also check the IP settings on your PC. It should be setup to use DHCP so that it picks up a valid IP/Netmask from the router.
Oct 25, 2009 | Computers & Internet
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Apr 27, 2009 | NetGear WGT624 Wireless Router
Can not get security for dlink
You may need to access your router setup page to verify the wireless settings in the router. Using a computer that is wired to the router, open up IE and type 192.168.0.1, that is the default IP address of your router. Then, a window will open asking for a username password. The username by default is admin. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left side of the page. On the Wireless page, you will see the wireless settings set in the router. You may also enable the wireless security on that page if there is not security enabled yet.
Please check this for your reference http://support.dlink.com/Emulators/di524/h_wireless.html
Hope this helps!
Nov 09, 2008 | Computers & Internet
Edimax BR-6216Mg Wireless Router (BR6216MG) Logo
112 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
