Question about DFI LanParty PRO875 Motherboard
What's the fastest chip I can put in an Intel G845GBV motherboard? Has a 1.7G at the moment.
MotherBoard: Hewlett-Packard 080Ch Serial Number: SGH31601C5 Bus Clock: 533 megahertz
any prescott/netburst based xeon- basically, any xeon before the advent of the core2 archetecture.
depending on your motherboard's voltages, the fastest upgrade you can count on would be to a 3.2ghz chip with a notably larger cpu cache.
you could check with hp support for any bios updates to allow for newer chips; however, even if available, bios "flashes" completely destroy the motherboard if the smallest glitch occurred during the process
Aug 27, 2014 | Computers & Internet
Is there a cpu upgrade for an hp pavilion 6835 with a motherboard 115561 cognac 20000731
The fastest Pentium 3 that will work in your board is a Intel Pentium III 1GHz chip. Here is a link to the specs:
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201000%20-%20RB80526PY001256%20%28BX80526F1000256%29.html
You could also get a Intel Celeron 1.1 GHz but it only has half the level 2 cache size so it's actually a bit slower than the Pentium III 1GHz chip.
Here's a link to celeron specs:
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20%28BX80526F1100128%29.html
May 23, 2012 | Powerleap PL-NEO/T Celeron, 1.4 GHz...
What is the fastest cpu chip you can put in the mother board
Your motherboard supports the following processor upgrades:
  • Intel Core 2 Quad (Y) Q9xxxx
  • Intel Core 2 Duo (W) E8xxx
  • Intel Core 2 Quad (K) up to Q6600
  • Core 2 Duo E6x00 (C) up to E6700
  • Core 2 Duo E4x00 (C) up to E4400
Oct 08, 2010 | HEWLETT-PACKARD 461068001 Motherboard
Performance motherboard for Intel Quad Core Q66
Asus makethe majority of the board in the world. Intel makes most of the chips sets and CPUs, which you alread have.  Which model depends upon what features you want(What you are intending to do). Get the board with the most PCIe16 slots and tie them all together in addition to the one having the highest amount or Ram availableto run,and the fastest Front Side Buss speed. That should take care of you.  I had built one  with the Q6600 and used an MSI board with two 8800 video cards and 8GB RAM
Feb 28, 2009 | Intel Motherboard
Dell Intel P4 Chip
Your chip is a socket 478, the fastest chip you can get for that system that is still for sale is:
Pentium 4 3.0 http://www.newegg.com/Product/Product.aspx?Item=N82E16819116027
Jan 18, 2009 | Dell Dimension 2400 PC Desktop
Thank You for solutions.
This is the fastest processor ypu motherboard is the Intel Pentium 4 Extreme Edition 3.73 GHz - JM80547PH1092MM (BX80547PH3730F) That is the fastest you can get in socket 478.
Dec 04, 2008 | Intel Motherboard
Motherboard
2.2Ghz should be the fastest for your motherboard, also the cpus FSB is MAX 400Mhz
the socket is S478
only old cpus work in your motherboard new and currently being sold, core 2 duo family prosessors wont work. they all have fsb 667 or higher and your motherboard only supports up to 400fsb
here is the best cpu for your pc
http://cgi.ebay.com/Intel-P4-2-2-Ghz-CPU-400-512-478-Socket-Northwood-SL6PL_W0QQitemZ260222969857QQihZ016QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I would recommend a whole new system.
Apr 05, 2008 | Computers & Internet
Processor up grade
The fastest cpu you can use on your mb is a pentium 3 800. Providing that you have the latest bios update.
check this link here.
You may need to download and install bios update from factory website .
Feb 22, 2008 | Intel Desktop Board SE440BX-2 Motherboard
CPU
According to Intel, a Pentium 4 ExtremeEdition with a 1066mhz FSB.
Oct 19, 2007 | Intel D955XBKLKR (890552602261)...
DFI LanParty PRO875 Motherboard Logo
48 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
