Question about KitchenAid Blenders
How to remove blender rubber coupler - KitchenAid Blenders
  • 185 Answers
It's reversed threaded. tap in cw direction to remove. use a flat blade screwdriver and small hammer.
Posted on Aug 23, 2010
SOURCE: Kitchen Aid Blender Rubber Coupling replacement
Someone else suggested a link that explains exactly how to unthread the old coupling... and it works. It took me about 90 seconds to fix my blender. But in case that link is dead, here's a summary:
(1) Note that the coupling (the round part with teeth) is threaded to the blender motor in reverse to a standard threading. So it screws off just like a bottle top, but in a clockwise direction.
(2) place the blender base on a tabletop, facing you. You should probably unplug it.
(3) take a punch or a flathead screwdriver, and place it against one of the coupling teeth that is furtherest away from you.
(4) strike the back of the screwdriver with a small hammer or maillot. The result will spin coupling clockwise. It may take several tries, but the coupling will eventually spin clockwise faster than the motor, and it will begin to unthread.
(5) unscrew the old coupling, and screw the new coupling into place (counterclockwise). Note that the new coupling will tighten itself every time you use your blender, so no need to worry about tightening it too much.
(6) Make a smoothie to celebrate your success!
Posted on Nov 10, 2007
  • 16 Answers
SOURCE: Hamilton Beach blender rubber drive removal
plz cont -23051554 \ 23095757
Posted on Aug 05, 2008
  • 5 Answers
SOURCE: how do i remove the rubber clutch of my kitchenaid blender
Grab the blade with a rag so you don't cut yourself, then grab the clutch with another rag and turn CLOCKWISE. It's threaded reverse - took me hours to figure this out. I found grabbing with rags or maybe towels worked the best. That should work
Posted on Jan 15, 2010
SOURCE: Rubber coupler on blender sheared off
Yes, it is very easy to fix. You will need a new coupler, which is part number 9704230. There is a set of instructions with video here: http://www.kaparts.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx
Posted on Feb 13, 2010
SOURCE: Krups 239 blender drive gear.
Like you, I am all for repairing and keeping the world free of blenders that only need one part replaced. The rubber coupling was easily ordered online, the challenge I later found was to remove it without losing my sanity. After messing up the side grill of the blender pretty good, I realized there is an opening on the motor casing that allows access to a "gear" that is firmly attached to the axle where our little friend will hopefully screw on and restore the contraption to a working state. In order for you to see (which I must warn you, it's not much of a view) through the grill you will need a flashlight or book light. Towards the top of the aforementioned gear (not the rubber part) there is a groove in which a flat screwdriver can easily fit immobilizing the axle and allowing you to easily unscrew it. Oh, but wait, I forgot this is the faulty part and it will spin without the slightest torque on the axle thus never loosening or getting it unscrewed. My solution to this problem was to surgically remove as much rubber as possible to allow me to attach my vise grip to the nut and finally put this thing out of its misery. Using the same procedure of inserting the screwdriver to immobilize the axle I was able to screw the new part and voila the blender is fixed!!!!
Posted on Aug 11, 2010
How can I change the blade for my 2 speed hand mixer? The model type is NC-12 if you need to know
you are using your KitchenAid blender and it stops blending, you may think there is a problem with the motor in your machine. However, a common reason for the blades not rotating in the blender is a dirty or faulty coupler. The coupler is what connects your blender dispenser to the motor, and you can easily replace the coupler at any time by only using a screwdriver.
Things You'll Need
  • Flat-blade screwdriver
    • 1 Turn the blender dispenser clockwise and lift up to remove it. Set the blender dispenser aside.
    • 2 Insert a flat-blade screwdriver between the black drive coupler and the frame of the blender on the top center portion of the blender.
    • 3 Lift the screwdriver upward, and the coupler will start to bend out of place. Slightly turn the coupler and then lift up on the screwdriver again.
    • 4 Continue to move the coupler slightly and lift the screwdriver until the coupler is completely removed.
    • 5 Insert the new coupler over the blender's motor blade and then twist the coupler counter-clockwise until it is tightly fastened.
Jun 07, 2011 | Blenders
How to remove the cutters on model ksb560mco pctag@verizon.net
The cutters are part of the collar itself and not available as a separate part. If there is anything wrong with them you need to replace the whole collar. The collars are available on Amazon UK, K A Parts as well as other places.
Dec 31, 2010 | KitchenAid KSB560 5 Speed Blender
Feb 13, 2010 | KitchenAid KSB3 Classic Work Top Blender
Seems like motor has lost power
This sounds like the black rubber coupler has broken. The teeth often get knocked off. Have a look at the part shown in hte pictures here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
Jan 22, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
How do I remove the coupler from a Kitchenaid blender, model: KSB560BW0. There seems to be confusion between different models and how to remove it. I have tried prying, and unscrewing clockwise, and...
I just worked on mine tonight. you have to take the bottom off by removing the four rubber feet and then the four screws under them. Now here's the tricky part; you'll need something to hold the jar coupler (round thing spins the blade). I was able to use a large pair of vice grips with some electrical tape wrapped around the jaws, to keep from damaging the coupler. Then take a slot edge screw driver and back out shaft from the coupler. FYI, the threads are reverse, so you will actually be turning the screwdriver clockwise to remove the coupler.
Aug 30, 2009 | KitchenAid KSB560 5 Speed Blender
I need to replace my rubber spinner with a new one. Where can I get the part and how do I take the old one off and put the new one on?
Hi, you have broken the coupler (sometimes called a coupling). It is relatively cheap and easy to replace. In the UK, K A Parts Limited sell them here and provide removal instructions here.
Aug 11, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The black rubber that blender sits on is breaking off.
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Jun 26, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The rubber gear that turns the blade in the kitchen aid blender is stripped how do i get a new one or a new blender?
Jun 25, 2009 | KitchenAid KSB560WH 5-Speed Blender
Square drive pin for Osterizer blenders?
I simply slid a small screwdriver in through one of the holes under the base to prevent the fan from spinning and unscrewed the pin counterclockwise using some small channel lock pliers. No disassembly necessary.
Jan 26, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Replacing rubber drive coupling
My coupler was split in two, and I couldn't screw it off. I had to do the following:
1. Take the blender apart (mine had 2 screws on the bottom). 2. Remove the motor housing from the blender (mine was loose from removing the two screws earlier). 3. Remove the fan by removing the fan nut. 4. Take apart the motor housing. Mine had two machine screws with 1/4" hex heads holding a bracket that tied the two ends together. Once those two screws are removed, you can take the motor out of the housing. Be careful on the fan end of the motor, because it's got two spring loaded brushes that will come together once the motor is pulled through. 6. Once you have the motor out of the housing, you'll have something to grab onto so you'll be able to unscrew the broken coupler. I used a pair of channel locks and gently grasped the motor body, and then just used a regular pair of pliers to grab the broken coupler. It's regular thread (lefty lucy righty tighty), so twist accordingly.
Once you have the coupler off, just put everything back together. The hardest part is holding apart the spring loaded brushes while you push the fan end of the motor shaft back through the motor housing.
Took me about 20 minutes to do everything.
Good luck.
Nov 20, 2008 | Oster 4093-8 Osterizer Classic Blender...
Blenders Logo
461 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
