Question about Sub-Zero 632 / S
The metal magnetic strip on the door jambs pop off. Can they be glued to the magnets?
GE fridge magnetic strip in right hand door needs to be re-installed, how can i do that?
The magnetic strip (very dark brown) is usually embedded inside a similar square hollow tube all the way around the door gasket. For it to have come out, there has to be a cut, slice or hole in the outer coating of the gasket. Press all the way around the gasket and you should feel the hollow spot where the gasket came out. It will feel solid where the magnetic strip is still in there.
Apr 04, 2015 | GE Refrigerators
How can i fix a collapsable baton magnet
epoxy the magnet in place.
Jun 04, 2014 | Work Safety
Nissan sentra rear view mirror
local parts store should carry special glue to adhere the metal tab to the windshield
Jan 08, 2018 | Cars & Trucks
Freezer door does not have the vacuum suction that it did have
Check the door is square to the frame and no shelves are sticking out stopping the door from closing properly. The seal should be magnetic and stick to the frame quite well.Check no metal strips have come off so the magnetic seal isn't attaching to the frame
May 20, 2012 | Frigidaire 20 cu. ft. / 566 liter Upright...
When I put my game in the xbox 360 it makes a grinding noise and will not load.
This could be a magnet issue, on top of the dvd drive motor there is a magnet that can become detatched, the dvd drive needs to be stripped down and the magnet glued back on, this is usually the case if its a grinding noise.
Hope this helps.
Jan 10, 2010 | Microsoft Xbox 360 Console
Where do I find the color code on the car? Thanx
Color Chart 05 06 07 08 09 10 Black (202)
Blizzard Pearl (070)
Blue Mirage Metallic (8R5)
Cassis Pearl (3Q7)
Classic Silver Metallic (1F7)
Cocoa Bean Metallic (4U5)
Desert Sand Mica (4Q2)
Indigo Ink Pearl (8P4)
Magnetic Gray Metallic (1G3)
Phantom Gray Pearl (1E3)
Sandy Beach Metallic (4T8)
Silver Pine Mica (6U0)
Titanium Metallic (1D4)
Codes are located on the drivers side front door jamb. Thank you , Quinn Texada
Nov 07, 2009 | 1999 Toyota Avalon
Kenmore 596.50692000 refrigerator. Every time I shut the refrigerator door, the freezer door pop open. What can I do? Do I need to replace the magnetic strip around the door? Who can give me instructions?...
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Let me know if this helps, Thanks, Sea Breeze
Mar 25, 2009 | Kenmore Refrigerators
Removing Door Panels on Sub Zero 532
Hi, there is a metal strip that runs down the middle of each door the entire lenth. It is held on with two magnets. Once you pull that strip of metal off, you will see five screws that hold the door handle on. Remove thos five screws and the entire handle comes free. Slide out the panel and replace the handle, screws and metal strip ion reverse order. Take your time removing the magnetic metal strip as it is a very soft metal and could possibly bend or kink up on you.
Hope this helps. I'm having some trouble locating any company that makes stainless stell to match the appliances. All of the metal companies say the appliance manufaturers have a propriety type of lock on the appliance metal finishes. I also have the 532 model.
Good Luck
Mar 25, 2009 | Refrigerators
How do i adjust doors so that they close on their own?????????????
Below is instructions on how to make sure doors open and close properly. Ignore the popping open part if this is not happening for you.
Mar 20, 2009 | GE Refrigerators
Kenmore Frig-bottom freezer/freezer door pops open
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Feb 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sub-Zero 632 / S Logo
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
