Internet only works if the internet cable is connected directly from modum to single computer so Actiontec Router is not providing wireless connection
  • 3 more comments
  • monicamonro Apr 27, 2008
    I have not found the solution from you AND YET I HAVE PAID????
    What do you mean configure my wifi???
    I have not rated this solution as I have not had it yet, was trying to find it and must have pushed the wrong button. PLEASE HELP IT HAS BEEN PAID FOR
    The model is Actiontec Wireless Cable/DSL Router No R3010UW
    I await feedback on my recent comment giving details of the wireless model - see above and please respond as I HAVE PAID FOR THIS
  • 813 Answers
U have to configer your wifi network then its will working
Posted on Apr 27, 2008
  • sandip panchal
    sandip panchal Apr 27, 2008
    u have to setup form in the router there is setting in a router so u have chanege the satting in the router then u will get the connectviy of your router can u tell me what the model of your router then i can sand link to how to setup wireless connaction in your router sand me ditels
  • sandip panchal
    sandip panchal Apr 28, 2008
Routor not connecting to modum
That is connect.
You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router.
Open the setup page of the router.
Change the Internet connection settings according to the Internet service provider.
Create a wireless network and then connect your computer and other devices to the wireless network.
Read more about How to setup Linksys router.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I am trying to log on with an ipod. The router is an actiontec gt704wg and I am asked to join the network TK096. I have tried the password "password" but no luck. ???
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 26, 2011 | Actiontec GT704WG Wireless Router...
Hello. I bought this modem with wi fi ,dsl router. How to set it to use this modem as a router.I want to connect my pc with lan cord & use wifi connection with my laptop and phones.
Turn DSL-router off.
Turn Actiontec off.
Turn computer off.
Connect:
* telephone-port in wall <--- 4-pin telephone wire --> DSL router
* Ethernet port on DSL-router <-- Ethernet cable --> WAN port on router
* One of the LAN ports on router <-- Ethernet cable --> network-port on your computer.
Turn DSL-router on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn Actiontec on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn computer on, and boot it.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you saw)
Login to your router
Configure the wireless adapter inside the router
(enter an SSID, choose 'WPA' encryption, enter a password)
Disconnect the Ethernet cable from your computer
Click "View Available Wireless Networks",
and select the SSID that you provided.
Enter the password that you provided.
Oct 21, 2010 | Actiontec GT701WG Router (actiongt701wg)
How do I get my EnGenius ESR-9752 router to work with my Actiontec GT701 modem? I have a desk top computer using XP. I just bought a lap top with wireless capabilites. I want to run this system through the...
1. connect yellow cable from Actiontec to the internet port (labeled internet)
2. Power cycle the engenius router.
3. login to the Engenius and verify the status. You should an IP Address from the ISP (Internet Service Provider). If not then you will have to verify the IP address from the router.
4.Make sure the laptop the see the wireless connection.
5.Verify the "ESSID" if your router and connect.
Apr 25, 2010 | Computers & Internet
Using the router
First connect your router to computer then access your router as following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page .
Then set WAN settings as your internet service provider settings.
Enable DHCP.
Go to wireless enable wireless.
SEt wep security if you want secure wi fi.Add WEP code it is your password to connect internet so only who know the password are connect to your wi fi .
Then save settings and restart router.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | Actiontec GT704WG Wireless Router...
Hooking D-Link 655 to a Ambit Cable Modum with Charter Cable, Cannot Get it to Configure. When modum is directly plugged to modum internet is fine, but I cannot get throught he setup stage when hooking the...
I have dlink 2100ap wireless router any body had access my wireless network but i want to ristrect network just like network passkey how can i give my dlink 2100ap wireless router pass key please give me reply
Sep 24, 2009 | D-Link Computers & Internet
Loose connection
  1. Update the Firmware on your router.
  2. When you lose internet, look on your modem and make sure that no lights have gone out. (i.e. Cable) If this one goes out, it is your provider.
Jun 03, 2008 | Linksys Wireless-G WRT54G Router
INSTALLING ACTIONTEC WIRELESS ROUTER/MODEM
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | Actiontec GT704WG Wireless Router...
Actiontec Wireless Router not providing internet connection
hi firend
there thats the way but if u have wireless connetion in your router & if u have wireless in your laptop then u can use easy in your home
Apr 27, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
