Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
I have a kenmore model 106 side by side and after changing water filter I have no water and no ice
    President:
  • 3,773 Answers
Check water volume at wall cutoff
Did you install the filter backwards?
If it is an inline filter in the back you can install it wrong way.
Check for kink in water line in back
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 06, 2010
Kenmore mod. 106 water does not get to ice maker and when pushing despenor no rotation of ice out door
Hello Jim,
Sorry it has taken me a while toget back to ya i just got.
So on your refrigerator it very likely is the switch forthe cradlethat ya push to dispense ice and water through the door.
Unfortunitly modelnumber 106 asyou have listed is only the source number of whom your Kenmore was made by. Typically the full model# that does start with 106 willbe on a label on the ceiling or side wall of the refrig. section inside of it, reply with complete model number please and i will be able to help ya disassamble the door dispenser as well as provide you with part numbers and such
Thanks for using FixYa.Com
GENE
Sep 29, 2011 | Kenmore Refrigerators
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
It's a Kenmore Model 106-56712500 , can't shut off alarm after changing filter, and now won't make ice or dispense water! How do I do a proper re-set code?
The 106.xxxxoooo Models are made by Whirlpool.
  • Whirlpool and KitchenAid - press the light switch 5 times within 10 seconds.
  • NOTE: If the fridge has a filter button, press and hold it for 5-10 seconds.
  • Changing the water filter should not cause the water and ice in door to not work. The actual freezer door switch will cause this problem. When the door is open ice and water in door are disabled. The door switch is a 3 contact switch. One contact is common, one turns the light on / off and one disables / enables ice and water in door. Manually depressing the door switch in the door fold hinge area should enable the water in door function. Do NOT test the ice function. If after you depress the light / door switch the light does not go out and the water in door does not work then the door switch has failed. The door switch is released from the cabinet by sliding either a putty knife or a knife blade along one side to unlock the locking tab. If the switch only has 2 terminals you have removed the wrong door switch. Check the other door.
    If your refrigerator has the wiring harness on the bottom of the door hinge there is the possibility that during the water filter change the connection of the door wiring connectors was loosened or broken. Just check to make sure that there is not a harness on the bottom of the door hinge. If there is a harness on the bottom of the door hinge make sure the connectors are connected.
    If you need more assistance just respond here and I will gladly help you.
    Thanks for choosing FixYa,
    Kelly
    Jan 11, 2011 | Kenmore Refrigerators
    Kenmore refrigerator model 106, 2doors, ice forms in the water inlet tube to the ice container
    I had the same problem and discovered that the water control valve was not shutting off completely between cycles. The water seeping through the valve was freezing in the water inlet tube. I replaced the water control valve for the icemaker and solved the problem.
    Mar 01, 2009 | Kenmore 53092 / 53094 Side by Side...
    Kenmore water on floor
    Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
    Jan 03, 2009 | Kenmore 57029 Side by Side Refrigerator
    ICE MAKER NOT WORKING
    Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
    Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
    Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
    155 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    oldblindman
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
