Question about Maytag MTB2176 Top Freezer Refrigerator
New refrigerator, about 3 months old, have ice maker, but it makes hollow ice! any thoughts?
    President:
  • 3,773 Answers
Check freezer temperature should be about at least 10 degrees or less but not below 0 degrees
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 06, 2010
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Making hollow ice cubes
Hollow ice is a sign of not enough water going into tray . Replace the water inlet valve (piece that the wall water line connects to on refrig ) .
Aug 29, 2009 | Refrigerators
I have a Jenn Air, french door style, bottom freezer. with the water dispenser on the inside left jamb of the box. there is also a ice maker. for the first 9 months every thing worked very well. then...
You have another plugged filter. That is why you ice cubes are hollow, the water is flowing so slowly into the ice maker, it does not fill up.
Recommend you install an external filter somewhere in the feeder line that connects to the rear of the refrigerator. The are surprisingly inexpensive, compared to the filter inside the new 'fridges. I recommend you buy a replacement external filter cartridge at the same time you buy the external filter kit. Of course you will need to change the internal filter one more time or bypass it per any instructions provided with your fridge.
Aug 11, 2009 | Refrigerators
Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker LFX25960ST
3 months old?? warranteed for a year call for service , you bought new so you wouldnt have to fix it!
Oct 31, 2008 | LG LFX25960ST Stainless Steel French Door...
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Ice maker
Hollow ice is a sign that the icemaker is not getting enough water.
You will want to make sure there is enough water coming to the fridge and any filters in the system are clean.
If you need help checking it, please post the complete model number from the fridge and I can help you more.
Nov 24, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
My 9 month side by side refrigerator
Hollow ice would suggest poor water flow due to a blocked water filter, check the water flow before and after the filter, make sure you flush the water line out before fitting a new filter. Cheers Colin
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MTB2176 Top Freezer Refrigerator Logo
67 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
