Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
27 hp kohler the motor will start but will not stay running it dies right after
  • Vaughn Teegarden Aug 17, 2013
    I had the same problem with my Kohlar 22 hp motor. If I run a wire from the + post on my battery to the fuel shut-off solenoid on the bottom of the carburator, it starts and runs fine, therefore a wiring problem. Haven't figured out where yet or a solution.
3 Suggested Answers
JVRjr
  • 3 Answers
SOURCE: My Kohler Confidant IV generator starts and runs
Kohler generators feed the generated voltage back into the control circuit board to tell it to keep the fuel pump (electric) runing and the ignition on. IF there is no voltage generated (bad brushes or?) then the symptom you describe will occur. The motor runs fine, but it isn't generating electricity.
Jim Russell
Posted on Jun 15, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: 20 hp kohler leaking gas out front right side of motor
Check all your fuel hoses make sure they are not broken or any holes are in the lines themselves. Also clean out the Carb and all the ports leading to the engine with some carb cleaner. If you still have raw fuel leaking then you are going to have to replace the top gasket on the motor where your cylinders are located.
Posted on May 05, 2010
What to do? I have a craftsman GT 5000 with a 25 HP Kohler and it will run for about 10 minutes and then start cutting out and die. I have changed the fuel filter with no resolve. What should I look at...
Make sure the choke is coming off. Check the compression.Many times the head gasket may leak when the engine heats up. Also check for spark sometimes the magneto can heat up and quit after running a while. See if it will run if you prime with a little fuel, if so ,some of the Kohler engines this size have a fuel pump that could be failing. Check for vapor lock. It takes air and fuel properly mixed, spark and compression any of these missing the engine dies.
Aug 06, 2014 | Kohler Command Pro OHV Horizontal Engine...
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
My cub cadet won't stay running. I can mow for a will and it just sputters, and or dies. I let it cool off for about 10 minutes.It starts right up after it cools. It also starts to smoke when it gets...
Similar issue - buddies CubCadet with Kohler Courage 22 would not stay running. Turned out the coils got rusty where it interacts with flywheel. cleaned the contacts (be careful to shim for proper spacing) and ran like a top.
May 29, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
May 05, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
2 mowers 19.5 hp and 27hp kohler, both die when you let off brake
Sure sounds like an elusive safety switch to me. There's usually one on the seat, the blade control, and the brake.
Jun 04, 2009 | Garden
15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
450 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
