Question about Panasonic Audio Players & Recorders
My Panasonic SA-AK100 stereo suddenly cut off. When I press the power button to turn it back on it flashes "F61" then powers back off. How can I fix this problem?
  • 2,272 Answers
F61 this error is related to overheating in the unit.it shuts off because there is short in the connections and due to this the internal heat sink overheats.And this error F61 is shown on display. this problem is seen in this unit.to resolve this issue the heat sink temp needs to be checked and faulty component on the board needs to be replaced.in some cases this over heating is due to cooling fan problem.either there is dirt got collected on cooling fan blades.Or the cooling fan is got faulty or the cooling fans connections have got short and that needs replacement.also check the voltage regular and replace if its faulty. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 06, 2010
  • ashley_ross Aug 07, 2010
    How do I know what to replace? Should I wait and keep the stereo off for awhile to allow the unit to cool down and then try to power on?
F61 error message panasonic sa ak410
try cleaning out the fan and make sure it spins freely. If the unit detects that the fan isn't spinning it will shut off.
Oct 07, 2013 | Audio Players & Recorders
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
Panasonic Dvd stereo system model number SA-VK960 power supply is defective. is it possible to repair?
Your Panasonic SA-VX uses a Switch Mode Power Supply ( SMPS ). Do not ever attempt to fix it yourself unless you are well versed in electronics. ou can damage the system seriously. Seek professional help.
Mar 10, 2011 | Audio Players & Recorders
F61 cd stereo system SA-AK640
F61 is an Error Code,more specifically a Fault in the Power Amp,the Stereo will need to be sent into Panasonic for Repairs.
Jan 09, 2011 | Panasonic SC-AK640 Shelf System
I got panasonic- sa-ak240 stereo system i get F61 on the display then it shuts down to standbye.
F61 is an Error Code......it's basically indicating that something inside the stereo is malfunctioning or broken.
the stereo has gone into Protection mode.....could mean there is Direct Current on one of the output rails....most likely the Power Amplifier IC in your Stereo has gone bad....a new one should solve this problem....you'll need to send it in to Panasonic for replacement of the faulty parts.
Oct 28, 2010 | Panasonic SC-AK240 Shelf System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Nide code fore a panasonic cd stereo sistem
Most likely the regulator IC is defective. Part # C5BA00000105.
Jan 15, 2008 | Panasonic SC-AK600 CD Shelf System
142 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
