Question about Jack Lalanne Power Juicer (Stainless Steel)
Will not run - Jack Lalanne Power Juicer (Stainless Steel)
Mine either, went to juice and the motor was running but not strong, then it just quick working...would love a solution as i love my juices! your help would be appreciated
Posted on Aug 13, 2010
Overheating champion juicer
to the person. champion juicer running hot. if your blade is dull it will run hot bcuz its harder to turn and gets clogged easy. look online for new or less used blade.
Jun 13, 2014 | Champion G5NG853S Household Juice...
INSTRUCTION TO CLEAN AFTER USE
Cleaning the juicer immediately after use makes it really easy to clean. Run few cups of water through the machine while running and make sure to use a bristle brush to scrub the screen with after use.
Aug 10, 2013 | Jack Lalanne Power Juicer (Stainless...
How do you open the acme juicerator to clean out the extract
I have a 1962 manual which might be too old but here's what it says: When juicing is completed, simply remove the spring-clamp top, unscrew the wing nut or spring clutch that holds down the cutter blade, and all parts to be cleaned may be lifted from the base. Bowl and top, being non-porous, similar to glass, require only rinsing. Blade should be washed under running water, using a stiff brush. Since the basket is made of stainless steel, it, too, cleans easily. After taking out the the pulp, let cold water run on the outside of the basket while you brush the perforated section. Any remaining particles of pulp will be loosened and can be removed with a damp sponge or by rinsing. Dry and reassemble for next use. Turn machine on and let run a few seconds.
Hope this is of some help.
Sep 02, 2010 | Acme 5001 Supreme Juicerator Juice...
Need a manual for acme juicer 6001, juicer at least 30 years old
The juicer hasn't really changed over time, but you
need to be a little mechanically inclined to adjust
and keep it running properly. Call Waring at tel
1 800 492 7464. Good luck. Mine is 21 years
old and running like new.
Jul 30, 2010 | Acme 5001 Supreme Juicerator Juice...
Stuffed parsley into the juicer and the motor stopped
Push red reset button on bottom of juicer. The
juicer is not designed for leafy produce, only
apples, carrots, celery, etc.
Apr 22, 2010 | Acme 6001 Juice Extractor
Juicer will not run
Make sure the stainless bar running across the top is snug on the left and right groove. It has a shut off switch when not installed properly.
Jan 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Excessive vibration and movement of  acme 6001 juicer during use. Tried different products, using less, not helpful.
test by running empty for several minutes,, should be smooth running. then feed the juicer slowly. I have not seen a problem with what I feed in, solid or pulpy material not leafy material.
Jan 04, 2009 | Acme 5001 Supreme Juicerator Juice...
Breville JE95XL juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
Dec 26, 2008 | Breville JE95XL Juicer
Stoop running
very easy to take apart. since all the skin and hard parts of fuits and veg. are shredded theybtend to stick and bunch up in the machine, sumtimes against blades.clean after every use inside and out
Jan 09, 2008 | Jack Lalanne Power Juicer (Stainless...
Overtemp switch keep tripping
REMOVE BOTTOM AND TRY ADJUSTING
RESET BUTTON BY TWEAKING SMALL
SCREW ON BUTTON HOUSING. TURN
EITHER WAY TILL YOU HAVE LONGER
RUN TIME.
Sep 04, 2007 | Omega 9000 Juice Extractor
Jack Lalanne Power Juicer (Stainless Steel) Logo
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
