Toshiba 100hz dynamic frame screen scan screen broken need a replacment
  • Anonymous Jul 16, 2008
    ┬┐como puedo encender este tv sin el mando a distancia?
2 Suggested Answers
tvservice306
  • 458 Answers
SOURCE: broken outer screen on my toshiba progection
Manufacturer Toshiba Part Number 23311898 Description SCREEN FRESNEL 42H Manufacturer Toshiba Part Number 23311897 Description SCREEN LENT 42H81 Manufacturer Toshiba Part Number 23311863 Description SCREEN PROTECTOR
Posted on Nov 13, 2009
Hi, where can I find toshiba service.center here in iloilo?i need someone Who knows how to fix blue screens and audio problems of toshiba laptop..thanks
Your closest Toshiba centre in Visayas province would be in Cebu. The company is Tricom Dynamics
VISAYAS
Company Address(City) Area code Telephone Website/Email Tricom Dynamics, Inc. Level 2, Machay Building, 30 Gorordo Avenue, Cebu 032 231-0681 www.tricom.com.phicon-opwn.gif
Sep 02, 2014 | Computers & Internet
When i power my toshiba laptop how do i test my power inverter or back lite
The plastic frame in front of the LCD screen is the Display Bezel.
The screen Inverter is mounted at the bottom of the Screen Frame.
[The LCD screen is an assembly of layers. There is a metal frame resembling a picture frame; which keeps these layers in the factory set alignment; the Screen Frame ]
Therefore easy access. Just remove Display Bezel.
To test a screen Inverter requires a sensitive multimeter; read fairly expensive,
http://www.fonerbooks.com/test.htm
Due to the above, ease of access to replace, and generally low cost; the screen Inverter is just replaced.
Then on to the Backlight if this doesn't repair the problem.
Which brings me to this;
Safety
https://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A100/
The Toshiba Satellite A100-S8111TD Notebook PC, uses a single CCFL for a Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to it's larger 'cousins' used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
This means it is Highly breakable. Costs more in money to just replace the entire LCD screen, (Which has the Backlight built-in),
but cheaper when you compare to life, and limb.
Jus sayin'.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Toshiba Satellite A100-S8111TD Notebook
My screen on my toshiba laptop P775 comes on but looks broken
If you mean broken as in it has a crack, it has liquid effect leak or dark then yes you have a broken lcd
Replacing is not a difficult as it seems, mainly by removing a few screws around the frame hidding under the rubber pads, then sometime you also need to remove the keyboard/power control panel, then its jsut a case of removing the broken lcd and buying a replacement panel and fitting it.
heres me taking a panel out on another laptop but gives you the idea.
If your in London, then I can do the repair for, cost of parts + 20pounds + return delivery costs.
Feb 03, 2013 | Toshiba Satellite P775S7236 Notebook
What is the frame output ic
Hello
Frame output IC means nothing, but the VERTICAL OUTPUT IC. Every TV will have it, which will scan picture vertically at 50 or 60 Hz. [1 HZ means one frame per second. Normally TVs will have 50Hz, 60Hz and 100Hz vertical frequency]. As vertical frequency rat increases, the picture fliker wil decrease. High level high-cost TVs will have 100Hz or even more frequency will be used for vetical scanning.
In the case of computer monitors, the vertical frequency will vary from 60Hz to 120hz. You can see its picture stability, at this high frequency.
The IC [Integrated Circuit Chip], which generates the vertical frequency and outputs it called the vertical output [frame output] IC. OK
Wish you a Proseperous and Happy 2012.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | Televison & Video
The 17.1' display of my toshiba satellite P105 its broken, two white lines blocked de screen, and 1 half of de screen its blocked by blacki need the part number or de model of de display for replace my...
Just a quick note, before you go replace the entire screen, make sure it's not just a wiring problem. If so, it doesn't cost as much to replace the wires connecting the screen to the laptop. LCD's are much more expensive!
As for replacing the display, this website has information on the display, along with the ability to purchase it from their site. http://www.pelltechnology.com/Toshiba/Laptop/Toshiba-Portables-Satellite-P105-Series-S6024/Toshiba-Satellite-P105-S6024-LCD-Screen-Replacement-P350475.asp
Hope this works!
Apr 11, 2011 | Toshiba Satellite A105 Notebook
The screen is red when i turn on and the frame around the windows explorer is red. This hapen after my laptop full down from the table.
The LCD Is probably broken. It could possibly be the ribbon cable but the LCD would most likely need to be replaced.
Mar 06, 2011 | Toshiba Satellite L305-S5875 Notebook
Our phillips tv 100hz digital scan 29pt9418/79 won't power up
Yes,it about 90% of the times,it the power supply board.U can look around the power supply board for puff up bulge capacitors,replaced these caps will get ur power back.10% it ur Tuner signal board.If find no defective caps in ur power supply board.Tries websites Shopjimmy.com.Ebay.com to buy ethier refurbish power or tuner boards for the replacement.
Apr 04, 2010 | Philips 26PF9966 26 in. LCD Television
Broken outer screen on my toshiba progection
Nov 13, 2009 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
557 people viewed this question
Top Televison & Video Experts
Electro Med Services...
