Question about La Marzocco Linea Group 1 Espresso Machine
I just got my La Marzocco espresso machine, it seems working fine but the problem is the motor pump, it won't shut off. According to the technician the problem is the computer board, is this true?
  • josieadimla Aug 07, 2010
    Yes, it was helpful.
    Thank you!
  • 1,675 Answers
Hi this sounds like it could be the case, what happens is, the "computer"/electronics side of the machine has a built in timer, if the "computer" is faulty the timer will not work , the timer in specific for amount of water to be expelled from the nozzle, if it cannot do that the pump will continue to run the reason why water is not pumped all the time is that they have a pressure valve to stop the water, so yes i think he is correct in his assumption the "computer" hope that helps
Posted on Aug 06, 2010
My la Marzocco gs3 pressure valve does not reach 12 bars
Adjust the expansion valve after making sure the pump brew pressure is at 9bar.
Jan 19, 2013 | La Marzocco Linea Group 1 Espresso Machine
Commercial espresso machine
Sounds like the safety thermostats on the machine is tripping because the machine is overheating or the circuit breaker is tripping because machine needs more amperage.
Nov 14, 2012 | La Marzocco Coffee Makers & Espresso...
How do I increase grouphead pressure on la marzocco linea 2 group?
To increase dispense pressure you turn the adjustment screw at the pump. When pulling a shot (use espresso) on one group the bottom needle of the gauge should read 9bars while pulling the shot.
Dec 16, 2010 | La Marzocco Linea Series Group 3 Espresso...
La Marzocco GB 5, 2 group head boiler not starting. It says coffee boiler 1 30.8 C. Please help
New machine? check the thermal reset on top of the left group head. Press the red button and see what happens.....
Aug 17, 2010 | La Marzocco Linea Series Group 3 Espresso...
Over backflushing grouphead on double boiler linea la marzocco
No, just make sure that you rinse well and pull a shot and let it drain so that you do not serve soap to anyone.
Mar 30, 2010 | La Marzocco Linea Group 1 Espresso Machine
La Marzocco Expresso g3 how do you reouble
Check the thermostat on the top of the back boiler, if the red pin is up then, make sure that there is water in the boiler then push in pin and turn machine on. Now comes the exciting part we have to find out why the boiler overheated, is it because the elements are damaged or the pressure stat is not working properly.
Nov 05, 2009 | La Marzocco Linea Group 1 Espresso Machine
La Marzocco espresso machine troubleshooting
Where is the steam coming from the small valve on the top or the big tall one? If it is the tall one then the problem is in the block electrical box(pressure stat) on the left above the element, that may be stuck and not telling the machine that it has enough pressure turn off the elements.
Jun 20, 2009 | La Marzocco Coffee Makers & Espresso...
I need an operators manual
You can dowload one from LaMarzoccousa.com.
Dec 26, 2008 | La Marzocco Linea Series Group 3 Espresso...
Customer service phone number
Hi there!
You can find all details for La Marzocco Here
There is also an email form for any parts you require and other information there too.
If this works for you. Please spare a moment to rate as Fixya! thanks
Jun 19, 2008 | La Marzocco Coffee Makers & Espresso...
Unable to programme La Marzocco
hello
you need to check your flor meters. they could be scaled or dirty. you need to dismantle flowmeter that is on the side that is not working and clean it. make sure the water main is off and power is shut off. hope this helps.
Feb 29, 2008 | La Marzocco Linea Series Group 3 Espresso...
La Marzocco Linea Group 1 Espresso Machine Logo
21 people viewed this question
Top La Marzocco Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you a La Marzocco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
