Question about ASUS Eee 4G Notebook
After turninig off the PC the normal way, it will not start back into Windows XP. The only thing it goes on is the logo screen. I do get BIOS info and I tried by pressing F8 to go to start back Windows the normal way to no avail. Thanks
    Master:
  • 344 Answers
Try checking the bios to make sure that your hard drive is still functioning.. after you assure that it is working make sure you dont have a CD-ROM or flash drive plugged into the machine. they might be confusing it. after those fail you might need to find out if the boot sector was damaged in some way or maybe even the boot loader. on another maching you can find software on the internet called Hiren's Boot Disc. this has a lot of helpful software to help clear up the issue.
Posted on Aug 06, 2010
Cant flash bios a1410n
Try simple first. When booting, AND BEFORE the XP logo, press f8 repeatedly until you see the boot options menu. If you miss it, you will see the xp loading logo, if so, restart and try again. From the boot menu, try the "boot with last known good configuration" option. If that doesn't fix it, re-boot, f8, and try the "safe mode" option. If it boots with any of these methods, do a full shut down and re-start again normally.
If that doesn't get it to boot normally, I would do the following. (I would, but you should only try this if you have a good understanding of windows and needed programs installing, ram replacement, hard drive repair/replacement and internal computer wiring)
Now, if your computer worked fine, then suddenly started this loop, I dont think it a bios problem. I expect you might have a hardware problem. Did you change any hardware very recently? Sometimes that stops windows from loading. Or, you could try changing the ram and retry, could be bad ram. But I think it is a hard drive issue. I think you will have to reload windows and/or replace the hard drive.
To safeguard your info, you should replace the main hard drive with another drive, load windows fully on it, then add the original drive back in as a slave/secondary drive, and retreive your personal info and files from it. Your needed programs will have to be re-installed on the newer windows drive. When you get all your files copied over (use copy and paste, not cut and paste), you can format the old drive and use it as storage, or just format and keep for the next time, or sell it. I would also run a "drive fitness program" to test it for bad sectors.
Or, if you dont need anything from your windows, you could format and install from the xp install cd. If it loads and runs, the drive is probably ok (I would still test it for bad sectors), or, if it cant load because of errors, the drive is probably bad. Retry with a new drive.
Jul 16, 2013 | HP Pavilion a1410n (ER890AA) PC Desktop
I was trying to update the Bios when my pocket pc went to a screen that has the word "Serial" at the top, a hp blue logo in the center with the word invent underneath it and at the bottom it has a v1.08. I...
Not a problem it happens just go to hp.com download the bios driver and use it on windows xp it will not work with anyother windows and run it with your ipaq connected to the pc. This will reinstall the complete bios software and bring it back to factory.
Aug 10, 2010 | HP iPAQ H2200 Pocket PC
Dell logo then blank screen
you to first put everthing back into your computer then make sure the hard drive is still working by checking your hard drive light see if it is light up or not go into the bios and make sure the computer is set to boot up for your cd rom first and second the hard drive now if you have windows xp home full you will be able to put windows xp full back on the computer if you have upgrade you will need windows 98 se to use for some of the files that the upgrade doesn't have once you do this it should be able to reinstall windows xp and if that doesn't work put windows 98se in the computer and then use the windows xp upgarde to put windows xp back on the computer if none if this work get back to me with more info and I will try to help you get back on track
thank you and good luck
Mar 23, 2009 | Dell Computers & Internet
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
Startup problem
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Dec 20, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Trying to reformat my PC but can't get into BIOS set up.
Hey,
Seems the screen is slow to start up, right after pressing the power button, keep tapping on f1 or f10 untill the bios screen or something else comes up. that will definitely get you into the bios and dont mind if the computer starts to beep, slow down a little and keep tapping.
Thanks,
Ekse
Aug 30, 2008 | Computers & Internet
Booting up
Try to start up with the windows XP CD in the drive, it will give you some options to reinstall or repair XP. If this doesnot work, ensure that your BIOS will startup from CD.
Aug 18, 2008 | Gateway MX6453 Notebook
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
Laptop troubles
I will reinstall windows XP, or your batery Bios is completely dead
Aug 27, 2007 | HP Pavilion ze2000 Notebook
ASUS Eee 4G Notebook Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
