Question about Microsoft Internet Explorer 8
I installed win7pro. can't find ie nowhere. why?
    President:
  • 2,571 Answers
If it was a cracked/pirate copy, try another version. You may just have a bad copy.
Try downloading firefox onto a pen drive then installing on that pc.
If it was a Full retail copy of windows, just try again, go into advanced settings on install and delete the previous partition/installation
Posted on Aug 06, 2010
How do I reinstall my graphics card since I installed win 7 pro
Hi
I presume that the installation of Win7Pro was an upgrade from a previous OS and that the graphics card was obtained before Win7 was available, as this would explain the lack of drivers for Win7Pro on the disk. If you go here:
AMD Catalyst Display Driver
you will be taken straight to a page where you can download the drivers for installation.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 09, 2014 | XFX Computers & Internet
Dell bios system password
If you have a BIOS password on "your" laptop, you have a very nice paperweight. The newer Dell laptops are no longer BIOS crackable like the older C and D series Dells were.
Apr 01, 2013 | Dell Inspirion 1521 Black - 1.9GHz...
Help how to remove old boot of winxp prof, in win7prof, please i was using windows xp ,then the other day i was installing xp on top of the other because the computer was affected, then the system drive...
Open "RUN" then type "msconfig"
Click on "Boot", choose which one of OS you want to delete and then click "Delete".
After that, click Ok to apply settings
Dec 07, 2012 | Computers & Internet
How do i change my default home page
Go to control panel
Go to network & internet
Click internet options
On the general tab
Where it says Home Page
Type in what you want for a home page & click apply & ok
see if this helps
Mar 17, 2012 | Computers & Internet
How to get Google back to English ?
Clear your internet cache and then try switching to English
Dec 30, 2011 | Dell Computers & Internet
I run win7Pro & AG CreataCard Platinum 8 will not install..is my favorite card making program for family & friends, any help appreciated.
CreataCard Platinum 8 was written for XP and older versions of Windows. Changes in the OS make it difficult/impossible to install.
Do you have the 32-bit or the 64-bit version of Win7Pro? Click Start > Control Panel > System and Security > System. If the title reads Windows 7 Professional x64, it's the 64-bit version. (If it doesn't end with the x64, you have the 32-bit version.)
In any case, the best option is to try running an older version of Windows on another machine, a dual boot system or a virtual computer. With the Pro version of Win7, you can run a virtual XP for free (if your hardware can support it). Download and install Virtual PC and the XP mode package from Microsoft. (You'll need to set aside some memory for the virtual PC to run.) Then install CreataCard when running XP mode as if this is your only computer.
The only real problem is that you will not be able to have hardware installed on the virtual XP and the Windows 7 real machine at the same time. (So you can't share a printer.) Also, to share files between the two "systems", you will need to save them to external media (flash drive or optical disc, for example). Your motherboard and CPU need to support Virtualization. You have to turn this on in your BIOS on some systems. (Press Esc, F1, F2 or F10 repeatedly depending on your system right after turning on the system. If you miss the timing, shut down the computer and then retry.)
Other virtualization programs are Parallels and VMWare. However, with those programs and the other possible options for running CreataCard, you need a licensed version of the older version of Windows.
If you have the 32-bit version of Windows, you can try the Compatibility Mode. (Right click on the installer and choose Properties. Then click on the Compatibility tab and select Run the program as compatible with an older version of Windows. Apply the changes and click OK. Then right click on the installer again and choose Run As Administrator.) You may have to repeat this on the program icon after installing. However, the compatibility mode doesn't always work even if you have the 32-bit OS (and thus don't need the signed driver).
An alternative is to upgrade your software to one that is Win7 compatible. I'm not sure which of these Broderbund design and print products are most similar to CreataCard: http://www.broderbund.com/c-6-design-print.aspx . However, you will probably not be able to open old documents.
I hope this helps.
(XP mode is available with Win7Pro and Ultimate. At my house, we have two computers with Win7Pro with one running XP mode. At least once, the virtualization was turned off during a BIOS update and XP mode failed until the setting was corrected.)
Dec 24, 2011 | Broderbund American Greetings Creatacard...
ASUS Motherboard AT5IONT-I, Win7pro,4G RAM,SSD. Everything works fine with a screen plugged into the DVI connector. HDMI output does not recognize any screen, tried everything, installed latest Nvidia...
i have the same problem!
AT5IONT-I, Win7pro,4G, bios 0502
tried many screens, nvidia driver versions etc.
hdmi only works in single monitor configuration. hdmi blanks on detection of dvi monitor. argh!
Apr 18, 2011 | ASUS Motherboard AT5IONT-I Atom D525 ION...
How do i get internet on my computer with a wireless router
Is your computer near to the router? If so, simply use the network cable (sometimes called ethernet cable) which was supplied with your router to connect the PC.
This is a better solution than relying on wireless.
However if your computer is nowhere near the router then you will need to use wireless. Does your computer have a wireless facility? (ie a built-in wifi card?). If not it will need one. If it does have a wifi card then please provide a little more information - operating system on computer (ie Windows XP, WIndows Vista etc) and ideally some information about the computer, (ie make model etc).
Nov 29, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
18 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
