Question about Bosch 7 - 1/4" Skilsaw Circular Saw
How to change blade on model 315.108220 circular saw
  • 313 Answers
SOURCE: finding the lock button..changing a
older model of circular saw dont have a spindle lock.wedge the blade on a bench vise & make sure ur not clamping the teeth of the blade & then turn the blade screw clock wise.
Posted on Aug 09, 2008
karmacanic
  • 16 Answers
SOURCE: Older Porter cable circular saw blade removal
Clamp a pair of vise-grips onto the blade to act as a blade-lock to stop rotation of the blade.
Posted on Oct 27, 2008
  • 15 Answers
SOURCE: How to keep the blade guard off the Circular saw blade when in use?
What is (B and Q) stand for ? This is a circular saw or a table saw, or a miter/chop saw?
Posted on Nov 18, 2008
muttandjeff
  • 359 Answers
SOURCE: how to lock blade on older circular saw
ONE WAY IS TO TAKE A PAIR OF VISE-GRIP PLIERS ,LOCK THEM ONTO THE BLADE VERY TIGHT WHEN THEY TURN UP AGAINST THE BED OF THE SAW YOU SHOULD BE ABLE TO REMOVE THE BOLT THAT HOLDS THE BLADE WORKS WELL DID IT LOTS ( bear in mind some of the bolts are left hand threaded so if does not go one way try the other )
Posted on Nov 24, 2008
muttandjeff
  • 359 Answers
SOURCE: how do i change the blade on craftsman circular saw?
some saws don't have a blade brake , i always take a pair of vise grips and adjust to grip blade tightly and hold or bind against housing then remove bolts works well for me
Posted on Jan 02, 2009
Where can we buy replacement blades?
Circular Saw Blades from Freud Sold Online - Tools Plus
www.tools-plus.com/freud-circular-saw-blades.html
Saw Blades for Less at Tools-Plus.com. Free Shipping on 1000's of Products.
Circular Saw Blades, ALL Sizes, ALL Brands Sold Online ...
www.tools-plus.com/supplies-power-tool-blades-circular-saw.html
Circular Saw Blades for Less at Tools-Plus.com. ... Shop with confidence knowing that Tools-Plus.com is an Authorized Internet Retailer. 3-3/8" Circular Saw Blades .... Saws and Replacement Blades ยท Automotive Hand Tools and Equipment ...
Nov 02, 2015 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
Can a 7 1/4" circular saw blade be used to replace
Some furniture shops used 7 1/4 circular saw blade for other brands of circular saw. Based on my experienced it's applicable as long their is clearance for the blade not touch the adjustable safety cover of the unit. Thanks for asking FixYa.
Jun 14, 2011 | Porter Cable Plywood Circular Saw Blade
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Cannot remove blade from craftsman circular saw
without knowing the model number I can only assume that it is a circular saw and the blade is on the right hand side and then the bolt should be a standard thread. Hold the spindle lock in and turn the bolt counter clockwise to loosen. If other than it would probably be a left hand thread and do just the opposite. Let me know and if so please provide the model number so I can look at a breakdown for the tool.
Jan 31, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
How do I change blade on Ryobi W-660 circular saw. I put some WD-40 on bolt, but it doesn't budge. To loosen, I turn clockwise?
I can't find that model number listed but generally a circular saw is standard thread, the mitre saw us left hand and a worm drive is also left hand thread.
Jan 02, 2010 | Ryobi Saws
How do i change the circular saw blade on my saw? because i cant get the blade out to swap it as its blunt and the blade is now blunt
After removing the blade bolt and the outer flange you will need to fully retract the lower guard (remove battery) and sometimes wiggle the blade but it will come out.
Aug 29, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Finding the lock button..changing a circular saw blade? "skill saw brand,usa" cannot seem to find it anywhere
Jul 03, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Bosch 7 - 1/4" Skilsaw Circular Saw Logo
606 people viewed this question
Top Bosch Saws Experts
Craig Butler
Craig Butler
Tim Venetis
Gary Nitowski
Are you a Bosch Saw Expert? Answer questions, earn points and help others
