Question about Boating
Where can I obtain torque specs for 50 hp Chrysler o/b powerhead?
    President:
  • 2,030 Answers
Can anyone.tell me the Torqe specs for a 2004 or cruiser
Head and Cam Bolt Torque specs? - PT Cruiser Forum
www.ptcruiserlinks.com > ... > Tech & Performance Forum
Nov 5, 2012 - 2 posts - ‎2 authors
I am putting everything back on after replacing the head gasket. I was wondering what the Torque Specs and Sequences are for both the Head ... Torque Specs
Jul 28, 2012
Valve cover torque specs
Jul 4, 2011
Timing Repair Project - Bolt Torque Specs
Jun 16, 2011
torque specs?
Mar 20, 2006
More results from www.ptcruiserlinks.com
Dodge Stratus / Chrysler Pt Cruiser / Sebring Camshafts ...
? 5:07
https://www.youtube.com/watch?v=2wB2o27eWgo
Aug 20, 2015 - Uploaded by World Mechanics
Dodge Stratus / Chrysler Pt Cruiser / Sebring Camshafts Install and Torque Specs 2.4 Engine. ... 2004 Chrysler PT CruiserCamshaft Install
Dodge Stratus / Chrysler Sebring / Pt Cruiser 2.4 Head ...
? 6:08
https://www.youtube.com/watch?v=7rY7tDbye-8
Aug 16, 2015 - Uploaded by World Mechanics
... Stratus / Chrysler Sebring / Pt Cruiser 2.4 Head gasket Install and torque specs We took this video to ... 2004 Chrysler PtCruiser head gasket
Jan 18, 2016 | Cars & Trucks
The torque specs for upper intake manifold 2006 chrysler pacifica 3.5
Tighten bolts gradually starting in the center working outward until a torque of 12 Nm (105 inch lbs.) is obtained.
Mar 16, 2015 | Chrysler Cars & Trucks
Where can I find plenum torque specs for 2004 chrysler 300m 3.5L? Replacing cam shaft position sensor
Depending on Your vehicle engine model, Vin #'s K, M, with a 3.5 ltr engine, the torque spec are 109 in lbs.
If the engine Vin # is a V, then the torque 113 in lbs
Jun 13, 2011 | 2004 Chrysler 300M
I'm looking for the Head Bolt torque specs for a 2005 dodge stratus 2.7L
STEP 1 TORQUE BOLTS 1 - 8 - 35 FT LBS STEP 2 TORQUE BOLTS 1 - 8 - 50 FT LBS STEP 3 TORQUE BOLTS 1 - 8 -50 FT LBS STEP 4 TORQUE BOLTS 1 - 8 - PLUS 1/4 TURN STEP 5 TORQUE BOLTS 9 - 11 21 FT LBS.
Sep 02, 2010 | Dodge Stratus Cars & Trucks
I need torque specs for the head bolts on a 2004 Dodge Stratus Coupe 2.4L SOHC
For 2004 Dodge Stratus 2.4L SFI SOHC 4cyl the Head Bolt Torque sequence
------------ | 10 6 2 3 7 | | 9 5 1 4 8 | ------------
Step: 1 - Torque to 25 ft/lbs
Steps: 2 - Torque to 50 ft/lbs
Steps: 3 - Torque to 50 ft/lbs
Steps: 4 - Turn 90 degreesRecheck final torque in sequence
Caution:Engine uses torque to yield head bolts (TTY) that permanently stretch during initial installation. New head bolts must be used when cylinder headis replaced or re installed to obtain proper torque specification.
Hope helps (remember comment and rated this).
Aug 02, 2010 | 2004 Dodge Stratus
Trying to fine the Weel Lug Nut torque on a 2008 Chrysler Sebring Convertible Limited with 3.5L V-6 and Aluminum Wheels.
Thanks for asking.... most people just use the German torque spec..... "Gut-n-Tight"
100 ft-lbs
and then Re-Check torque after 50 miles!!!
Cheers
Jun 04, 2010 | 2008 Chrysler Sebring Convertible
I need torque specs to change a water pump for a 1999 chrysler cirrus 2.4 liter engine. water pump torque specs.
dont know the specs but you should be ok if you tighten the bolts snuggly and then 1/2 turn this will usually suffice just be careful not to over tighten
Nov 01, 2009 | 1999 Chrysler Cirrus
Torque specs needed
do you have a Haynes reapir manual or Chiltons? if not you can get one from autozone or some other parts places, or you might find one in your local library, inside that book are all the torque specs you can stand.
Mar 23, 2009 | 1997 Chrysler Concorde
Boating Logo
26 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
