Coleman roof top air conditioner 7300
I have a Coleman roof top air conditioner model 7300. When the unit is running it is drawing 9 amps and when I put on a light in the unit the air conditioner kicks off. I have to wait a few min., put the light off and the air conditioner will restart and run fine. Supply voltage is 117 volts
5 Suggested Answers
SOURCE: fan not blowing in coleman trs rv roof air
how to gain access to fan motor on brisk air 579 series roof mount air conditioner. thanks
Posted on Jul 13, 2010
  • 1124 Answers
SOURCE: coleman 7300 rooftop air conditionor wont operate
When they sit allot - sometimes the fan will stick.. Take the cover off,, turn it on and see if the fan is stuck.. Spin it by hand to free it up..
Posted on Jul 09, 2009
  • 6674 Answers
SOURCE: Compressor trie to start, but don't.
Capacitor is good place to start, once you confirm you have proper voltage getting to the unit.
Posted on Jul 20, 2009
  • 6674 Answers
SOURCE: Hi, the roof top air conditioner drain keeps
Re: re-directing the water dripping over door ! Stop at RV parts store and get yourself a tube of "Dicor" self leveling sealant. It's recommended for rubber roofs, but works well on most roof surfaces.
Then I simply run a 3/8" bead of "Dicor" across wherever the run-off from AC is coming down, and re-direct it so the run-off comes off roof elsewhere. Don't try to smooth it out or anything, as I said, it is self leveling, just use a caulking gun, lay a bead about 3/8" and allow it to set for a few hours if you can. Make sure you pick a time where AC is off for a couple hours so (run-off) water isn't present. You"ll see the path (stain) on roof where it travels to guide you for redirecting. It's a simple fix, and no screws or nails required. Use the rest of the Dicor to fill in any gaps, cracks etc you see on sealant on the roof while your up there, but clean those before applying. If you can wipe your intended path down with some mild cleaner prior to applying bead, it will help it stick better as well. Even a little dish soap in water will do, just be careful, it gets pretty slippery when soap on there. Quick rinse with water then dry with rag, or let the sun dry it. Actually on a rubber roof, It should be scrubbed with mild detergent at least once a season anyway.
Posted on Feb 28, 2011
Testimonial: "Thanks. Great idea."
Btu of coleman 7830-901
That should be a 30,000 Btu unit. Its been a while since I worked on them. The 78 is the series or model, the 30 is the capacity or btu's and the 901 indicates it is a Copeland compressor.
Jun 09, 2014 | Coleman Air Conditioner Shroud Rv Roof Top...
Need to know the BTU's of a coleman rv roof air.
The limiting factor is the power available to run the device. Typically, roof air units are around 12,000 BTU.
Unless your rig is wired with a 50 amp service, you will not be able to run more than you have at the present with your 30 amp service. I have found that a rig with a microwave, a roof AC and a TV frequently cannot run all three at the same time. If you do have 50 amp service, you can add the second roof air. Also, if you have a 30 amp service, you can upgrade to 50 but that is an expensive proposition with the cord itself costing around $200.00. You would also have to upgrade the distribution panel and probably have a pro properly split up the load between the two 120 Volt AC buss'.
I hope this response helps you with your deliberation and thanks for your question @
Aug 06, 2011 | Coleman Heating & Cooling
I have a coleman Mach rooftop unit & want to connect drain tubing to carry condensate away. Is there a small drip pan with a tubing conncetion for this?
If all you want to do is re-route condensation dripping off the roof, and it's a rubber roof, one easy way is to buy a caulking tube of "Dicor" self leveling sealant for rubber roofs from RV dealer, and run a 1/4"-3/8" bead across roof from AC to wherever you want it to go, and let it cure for a couple of hours. Nobody sees it, and a tube is about $10 max.
Jun 09, 2010 | Coleman Mach III Air Conditioner
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
Coleman 1300, condensation buildup inside unit, ceiling wet
Check for plugged drains under cover on roof, sticking out at base of unit usually. It should be running off roof.
Aug 04, 2009 | Heating & Cooling
Coleman 7300 rooftop air conditionor wont operate
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
7300 Series AC
***I guess nobody knows the answer. Ok. I'll search elsewhere.
Jun 14, 2008 | Heating & Cooling
Roof top motor home coleman air conditioning unit
What is outside (ambient) temperature. When was entire unit last cleaned? (evaporator coils, & condensor coils)
Jun 04, 2008 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
1,133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
