When I press the power button, the unit clicks somewhere near the power supply, but it doesn't turn on. About 20 seconds later there is a second, quieter click. I pulled out a 125v 6.3A fuse near where the power cord plugs into a circuit board. The fuse wire bulges out in the center, like there is a bead in the middle of the wire. Is the fuse the problem or is it something else? Thanks for any help.
  • Brad Brown Jul 31, 2017
    Hi zerodukemit, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? make model and year?
  • 119 Answers
SOURCE: Kenwood KR V8080 receiver
if you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
Posted on Nov 02, 2006
robotek
  • 1512 Answers
SOURCE: unit wont turn on
.Hi jepenny
The board you are looking at is the standby cct and power switching PCB. It sounds like that is working, so you have probably lost power to the transformer primary or the transformer is open circuit. Check for blown fuses and replace with exact same type and rating.
Be sure to unplug at the wall before touching any internals!!
If you can find no blown fuses, the power transformer may have failed. Good luck, get back to me here is you need any more advice. Thanks for using "FixYa"
regards
Graeme
Posted on Feb 18, 2008
  • 4234 Answers
SOURCE: Kenwood Receiver KR-a5020 receiver won't come out of standby
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Nov 28, 2008
SOURCE: NAD 7140
The clicking is the sound of a bad relay. A relay is an electrical switch that opens and closes under the control of another electrical circuit. There is no user solution for this. You'll have to take it to an electronics repair shop (~$150) or dump the whole unit.
Posted on Dec 19, 2008
SOURCE: I turn it on, it clicks off within a few seconds.
It sounds like a problem with the power supply. You might be able to find a place that can fix it, but I don't know for sure. It also could be a broken solder joint in the power supply.
Posted on Jan 12, 2009
Zanussi FLE1416W trips consumer unit fuse switch.
A shorted wire or component somewhere
Nov 04, 2017 | Washing Machines
When i turn on my sansa e260 and show the sandisk logo, it restart showing the logo over and over without going to the main menu, how do i fix it ?
Hi, welcome to fixya!
You need to reset your sansa for it to be in order again.
Learn how to reset the your various San Disk models;
Resetting a Sansa Fuze+, Clip+, c200, e200, or e200R player:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Resetting a Sansa Express player:
NOTE: The device can be either ON of OFF.
1. Press-and-hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
2. Release the buttons.
If resetting doesn't solve the problem, please let me know for more assistance.
Good luck.
Nov 03, 2011 | SanDisk Sansa e260 MP3 Player
My hitachi will not power on when clicking the power button it comes on for a second or less and immediately clicks off
I have worked on a lot of these sets and in fact own one almost identical to yours. The shut off means either a "shut down" circuit is being engaged because of a problem somewhere in the set OR you may have the same problem mine had---here is what I did.
I plugged the set into a outlet controlled by a wall switch: turn set on and it shuts off, turn wall switch off for a second and back on and try turn set on.
In my case sometimes had to do this many times but eventually the set would come on. In my case problem turned out to be bad capacitor near the main power relay, that is the click you hear when try turn set on----if it will not come on after say 20 tries it is bad part most likely in power supply or even bad solder connections that develop after age in many set.
Let me know what you find and IF ANY QUESTIONS feel free to comment here and the site will email me so I can assist you.
SD TECH
Nov 26, 2010 | Hitachi 50GX30B 50". Rear Projection...
My son's 20" LCD Model LTV-2001 will not turn on.
Could be an open internal fuse or power supply failure
Jun 01, 2017 | Norcent Technologies TV2001 20 in. LCD...
My Hitachi 42HDT79 is having problems coming on. When powered up the red light in the lower right hand corner lights, but will not turn to blue indicating regular operation when either the remote or the...
I have the IDENTICAL problem!! I've opened up the back and pulled the 100v 3300uf capacitor from the power supply board as it is bulging. I'm going to replace it tomorrow when the stores open (1:20am as I write this) - hopefully a common enough cap that I can find one in stock somewhere locally (GTA). Various information on line seems to point to this as the culprit. Fingers crossed it'll work...............
Oct 29, 2010 | Hitachi 42HDT79 42 in. Plasma Television
MagicSing EG-18000 TV picture
i believed the problem is the TV mode. (NTSC or PAL mode)
try this
turn mic OFF
press and hold 8 then press power buton (PAL to NTSC)
or
turn mic OFF
press ang hold 9 then press power button (PAL to NTSC)
customerservice@magicmic.com
Sep 05, 2008 | Magic Sing Along Consumer Microphone
No Power in Mitsubishi VS-55705
Hi John This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Sep 11, 2007 | Televison & Video
Constant clicking every half-second as soon as you plug it in.
I have the same problem-still troubleshooting...so far still not find the cause. DM1 power supply output voltages are operates correctly. Signal output of microprocessor up and down (no good) that turn on Q14105 and latch optical isolator U14102 to power the unit but both of ohmed out ok. it hard to troubleshoot the main board with power on.
Aug 29, 2007 | RCA F38310 38" TV
21 people viewed this question
 Grubhead
Grubhead
