Question about Sony KP-57WS500 57" Rear Projection Television
Sony turns on and off again
Tv turns on bloe screen green and red shut down then looses picture and turns offf and has trace lines arched through screen on blue start up screen
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
Posted on May 05, 2008
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a green screen and shuts down after only about a minute
This model had a lot of problems with bad picture tubes--it has a red, green and blue picture tube--only now available on a rebuild basis.
There is something you can try if you are only a little bit handy--a do it yourself thing that involves no replacement of parts---
If set comes on and screen goes bright green and shuts off--it is shutdown circuit-detects too much current is being drawn and protects set.
I am able to post instructions here for you to try something simple that may let the set work again for a period of time.
Let me know if you want the instructions and I will post them here for you.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Sony KP-51WS500 51" Rear Projection...
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Kp57wv600
One of the convergence output IC's has stopped working and needs to be replaced. If the IC shorts out then it will draw too much current and possibly blow a fuse, and the set will shut down to protect itself. The IC should be replaced and the set realigned by someone with experience in convergence circuits.
Jun 20, 2007 | Sony KP-51WS500 51" Rear Projection...
Faint red lines in a curved arch like pattern
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
191 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
