Question about SMC EZ Connect Traveler's Kit (SMCWTK-G)
Device Model: SMCWTK-G PArt Number: 99-012084-377 SMC Networks I'm unable to configure the device since the "Configuration Utility" isn't detecting it. I'm following the instructions to the letter but haven't been able to get the Utility to recognize my device. I have Reseted the device several times using the procedure described in your FAQs but doesn't seem to work: 1) press the reset button for 15 secs, then unplug the power line for 15 more secs, finally plug the cable again and wait for 15 more secs without depressing the reset button during the whole time. I'm using the utility software downloaded directly from this site and also different cables to ensure the problem wasn't there. I just can't get the device to connect to my PC and be recognized by the application. Would appreciate your help on this issue. Regards, Luis N.
3 Suggested Answers
rahul26485
  • 611 Answers
SOURCE: Connection Problem
update the firmware of the all device
Posted on Jun 11, 2008
rahul26485
  • 611 Answers
SOURCE: SMC EZ Connect Access Point apparently not connecting to wired router
you doing something wrong there.
give the mac address of smc to the access point that's all you get it
Posted on Jun 20, 2008
Is there a driver for the SMC2870W and Mac OS X?
This is a standard wireless ethernet bridge and does not need a special driver for MAC OS. It is a Plug n Play device and should self configure using TCP/IP . Here is the manual : http://www.manualslib.com/manual/154817/Smc-Networks-Smc2870w.html?page=20#manual. Your Mac should see the wireless signal. You could use Safari browser to configure if needed. Apparently the Configuration utility is for older windows systems up to XP. You may need some networking skills to do the configuration without it. Good luck.
Mar 07, 2015 | Office Equipment & Supplies
I received the following message on my Laptop: "windows cannot configure this wireless connection", what can I do?
It sounds like your wifi device is configured by its own application. Look in your task bar (lower right corner of screen normally) for a wifi icon (ascending sound bars?) and right click on it for options. When you get into the configuration program, there is usually an option to select "Windows Zero Configuration" or "Let Windows handle this device" or something similar. Select this option and then try to access your local networks as usual by right clicking on the Windows network box. You MAY have to refresh the screen.
Good Luck.
Feb 19, 2015 | Computers & Internet
My laptop isn't giving off any sound. and it is saying no audio device installed how can i fix this
what is your laptop model? try going to there website and search for the audio drivers for you model and download them if you can give me the make and model i can find them for you
May 14, 2011 | Computers & Internet
I have a DIR-615 router and can not locate the device ownership password. It is not on the label beneath the MAC address. Any ideas?
This Device Ownership password is actually reffering to the WPS PIN number of your router which is usually on the sticker on the device. If you can't see it anywhere on the device, scan for wireless networks and connect to your network.
Once it will ask for the device Ownership password again, just click on the phrase that says " I want to enter a network key or passphrase instead" or " I don't want to configure, I just want to connect" ( this is applicable with vista ). If you have an XP computer and your using the wireless utility of your computer, disable that utility and use the Windows Zero Configuration.
Sep 18, 2010 | Linksys Wireless-G WRT54G Router
My wireless adaptor can not find my wireless router
Please check tour wireless adapter if its working and properly installed in your computer. Here's how to do it;
Checking Device Status on the Device Manager
For Windows 2000 or XP:
1. Click on Start, go to Settings and then Control Panel.
2. Click on System, go to Hardware and then Device Manager.
3. Click the (+) sign on Network Adapters and select the adapter.
4. Double click on it and read the Device Status.
If your wireless adapter is not working and installed properly, you have to re-install the wireless adapter software driver. When the wireless adapter is already properly installed you can follow this steps below;
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 10, 2009 | NetGear WGR614 Wireless Router
Belkin wireless G adapter shows as working but no networks
make sure the Wireless zero configuration or WLAN auto configuration service on your OS is running
Try to search for wireless network using the Belkin wireless utility after disabling windows
Nov 19, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
DWA-643 installed but unable to access any wireless point
check the status of the device under Device Manager first and see if it was properly installed. If yes, you may use the wireless zero configuration utility built-in to XP or Vista. If your OS is lower than XP you have the use the utility provided by D-link. It usually comes with a CD installer for its driver and utility.
Please rate and see if it helps. Thanks and goodluck.
Oct 10, 2008 | D-Link DWA-643 Wireless Adapter
Connection Problem
Feb 23, 2008 | SMC EZ Connect g SMCWEBT-G
Access configuration
Note: Not all D-Link routers, print servers and access points have a web-based configuration utility. Please check the manual for your particular product. In particular, the DWL-900AP does not have a web utility while the DWL-900AP+ does have a web utility. You cannot gain web-based configuration utility functionality for the DWL-900AP by installing the DWL900AP+ utility. When entering the IP address of the D-Link device (192.168.0.1 for example), you are not connecting to a website on the Internet or have to be connected to the Internet. The device has the utility built-in to a ROM chip in the device itself. Your computer must be on the same IP subnet to connect to the web-based utility. Make sure you have Java enabled and are using an updated web browser. We recommend the following: Internet Explorer 5.5 or higher Netscape 6 or higher Mozilla 1.2.1 (5.0) or higher Opera 6.0 or higher Safari 1.0 or higher (with Java 1.3.1 or higher) Camino 0.7 or higher Firefox 0.8 or higher -------------------------------------------------------------------------------- Internet Explorer 6 (SP1) users: If you continue to receive Error 500 when trying to connect to the web-based configuration of your D-Link device, make sure you have the latest Windows update for Explorer 6. -------------------------------------------------------------------------------- If you have Windows XP or Server 2003, you must download the latest Java patch from www.java.com. Click here to download patch - http://www.java.com/en/download/index.js... To resolve difficulties accessing a D-Link model that has a web utility, please follow the steps below. Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. What type of cable should I be using? - http://support.dlink.com/faq/view.asp?pr... Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer - http://support.dlink.com/faq/view.asp?pr... If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Click here to set a static IP address on your computer - http://support.dlink.com/faq/view.asp?pr... Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration. There are several more FAQs that cover the configuration of the different D-Link routers, Access Points and Print Servers.
Feb 16, 2006 | D-Link DI-704P Router
Computers & Internet Logo
43 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
