Question about Craftsman 10" Table Saw
Im trying to repair my crafstman table saw model #137.248830. Replacing the armature but cannot get the gears to line up correctly am i missing something?
  • 2,176 Answers
I would recheck the part number for the armature to ensure they have the same number and diameter of teeth. once you install the bearings this part should easily slide into the diaphragm and there is no alignment of the gears necessary. Let me know if I can be of more assistance.
Posted on Aug 09, 2010
How to change motor armature
Motor armature AND drive gear IF IT was worm or old , if it was overload then it depends or the noise it bring in difference in wear.
take a long pliers place on the anchor and beat with a heavy plastic hammer against the pliers the anchor out of the ball bearing.
Sep 07, 2016 | Ridgid 10 in. 15-Amp Heavy-Duty Portable...
Do parts for a model 3305 skil tablesaw interchange with a model 3400
numerous parts should. When you get to the armature and spur gear, then it gets a bit iffy.
Feb 13, 2012 | Skil 10" Table Saw
How do I get to the reduction gear in the aluminum housing?
generally all you need to do it "tap" the housing with a dead blow hammer and the armature will JUMP out of the diaphragm.. make sure there are no screws locking the bearing to the housing if not try the above.
Jul 19, 2010 | Craftsman 10" Table Saw
Motor replacement for Bosch Mitre saw
Most often the entire motor doesn't go bad. It would be a componen't like armature, field, brushes, Switch. I very seldomly see a whole motor go bad. look for a single problem. The saw is not junk it is very repairable with some testing of parts.
Jul 12, 2010 | Bosch 10" Slide Miter Saw
Failed electric motor on 10" Craftsman Table Saw
by seized is it burnt up or are the bearings just bad, the bearings are minimal but the field/armature would be more. Give me the model number and I will try and find a breakdown and let me know what we are looking for and I will try and help.
Sep 28, 2009 | Craftsman 10" Table Saw
Making a loud noise, motor turns slowly.
Sounds like you have a burnt up motor. When a motor overheats the armature and field will swell. This causes them to rub together which can cause more heat which in turn can cause the whole motor to seize. The problem with repairing a motor like this is that everything that the field and armature have come into contact with needs to be replaced. For example, bearings, boots, brushes and holders, wiring, and especially the housing. When you take a burnt up field out of a housing it may look fine, but the stresses cause by the expanded field will not allow the new field to sit in there correctly which will cause more problems down the line.
There could possibly be other problems, such as a broken commutator bar ( which could make a lot of noise).
The easiest way to find out if you have a burnt up motor is to flip the table saw over and remove the 4 screws that hold the motor in. Make sure your brushes are removed first. After you have the 4 screws out, try to remove the housing. If it gets stuck you know you have a swollen armature. If it doesn't you can inspect the comm bars for damage. Good luck
Sep 10, 2009 | Craftsman 10" Table Saw
Bosch table saw model 4000
It sounds like the pinion on the armature and or gear are stripped. The only way to find out is to tilt the blade and remove the motor housing from the diaphragm and check it. If replacing the armature I would recommend also replacing the bearings and brushes as preventative
Nov 08, 2008 | Saws
Craftsman 10" Table Saw Logo
108 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Tim Venetis
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
