Question about Sony KP-57WS500 57" Rear Projection Television
Tv turrns on and then off
Sony turns on blue looses the no signal sign fades then tv turns off turn it back on same thing
Posted on May 05, 2008
Turn on the big screen sony tv, but fades to blue
You probably have a bad BLUE CRT. Due to the cost and the length of time it would take to repair, I would not invest the money into it. It would require a Qualified Service Person to come to your home and remove the BLUE CRT assembly and send it back to SONY to be rebuilt. Estimated cost would be around 800.00. I would check prices of a replacement set.
I hope this helps,
Skyassoc
Oct 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Blue screen
This is easy to fix, pull off the front grill and turn the bottom left trim pot anti clockwise until the picture comes back. I am asuming the picture there and then it fades to blue. There is a step by step instruction on how to get the whole thing apart http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Aug 19, 2008 | Sony KP-46WT500 46" Rear Projection...
The picture on my Sony KP57WS500 is starting to fade to blue after being on a short period of time. ANY IDEAS?
Good Day;
A blue picture after it's been on for a bit is normally one of several things. The most common for your Sony is the CRT, tube, the second most common problem is the blue CRT 'IC'(chip). The IC is located is on the blue crt board.
The best way to determine this is to remove the speaker grill(on front of TV), then inner panel, the blue tube will be on your right hand side. Remove that little board at the end of the tube.THIS AFTER YOU HAVE UNPLUGGED THE POWER FROM THE WALL. Plug TV back in turn TV on. If TV comes on with picture and there is no blue in the picture, The tube is bad, if TV turns off it's the IC.
Good Luck, BI.
Jun 18, 2008 | Televison & Video
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Blue screen
this problem is due to blue video circuit. 1 Please check supply to blue video ckt. 2 check crt base for loose. 3 check loose contact & parts related to blue cathode. 4 blue signal coming from processor to blue video. 5 processor it self. 6 at last if tv is very old than check crt also.(possibility is rear) hope this will help.
Oct 03, 2007 | Sharp 32C-240 32" TV
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
