Question about Uniden Cordless Phone
My Phone went out ,I check with the PHONE COMPANY and they said the line was still working.The answering machine still work also the chargeing lights are on but the PHONE is dead.
  • julius_walla Aug 06, 2010
    There is no reset button.Everything on the PHONE works but there is no sound.
  • julius_walla Aug 08, 2010
    I will check the battey and the adaptor and also try another phone. Thank you:)
  • 3,866 Answers
I am finding in this case you need a new battery for the handset, because if the base powers then its the battery in the headset let me know.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 06, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Aug 06, 2010
    If the phone works but there is no sound then there is something that has gone wroung such as the AC adpator thatp lugs the phone in might not be putting out enough to the phone to totally power it you might want to check that as well.
How do you set the number of rings before the answering machine picks up?
Gonna need to know if this is an answering machine (box that connects to your phone line) or voicemail service offered by your phone company. If the latter, what company and is it a mobile phone.
Details are needed to get answers that work here
Nov 26, 2011 | Lands Phones
Tip
Troubleshooting for modem.
Problem:-
User's modem does not dial or does not connect.
Tip:-
Prove that computer is connected with phone line and check that phone line contains dial tone.Therefor check that connection is connect or not.
  • Connection may not be less than six feet (1.8 meter).
  • Check dial tone by plug in the phone in phone jack.
  • If user has many more services (such as call waiting,call messaging OR voice mail) then check that these all are cleared or not and check call waiting is disabled while using modem.
  • Disconnect any answering machine,fax machine or printer which are on line with modem.
  • Check that are you not using digital,rollover or PBX line?These type of lines not works with modem.
  • Try with another phone line. (For this, you have another phone number or another phone line).If user connected with another line then you need to complain in phone company.
  • Try to connect modem with low connection speed.
on Apr 13, 2010 | Computers & Internet
Display check phone line
Either your phone line is dead or your base station is not plugged in correctly (or broken). Buy a cheap non-wireless phone and check the phone jack. If that phone works your Panasonic was had the line plugged in correctly you need to buy a new phone. If not you need to call your phone company and get a repair scheduled. Note, the phone company will charge to repair phone lines if they are damaged inside your house.
Apr 22, 2011 | Panasonic KX-TG5632 Phone
My phone rings one time
There is a short somewhere on your line. Unplug all your phones answering machines etc... Try calling line if it just rings one of the things yo unplugged is short. plug one thing in at a time until the problem comes back when it does youve found your bad equipment.If unplugging all your equipment does not solve the problem contact your phone company. Note, the phone company will charge you for repairs inside your house.
Dec 10, 2010 | Uniden Cordless Phone
When a fax is coming through my machines says failed to connect, what is the problem?
hello sorry we got disconnected but please try this
Based on what I read in the Dell manual I would say the answering machine needs to pick up the line first so the number of rings to answer for the answering machine needs to be less than the rings for the printer (if you set the answer machine to pick on on the second ring set the printer for 3 rings).
Basically this looks like it works similar to other phone line sharing devices, if the manual is correct when the answer machine picks up the printer/fax is supposed to listen to the line, originating fax machines send what is called a CNG tone.
Looks like the machine listens for this tone, if it sees it then it is supposed to cut off the answer machine and complete its fax function, if the tone is not present the Dell should let the answer machine work normally.
From working with phone line sharing devices I have seen most problems occur in the home where people have a single line coming in and they tap off of that line and run jacks to all the rooms in the house.
This creates a problem, when you plug phones or answer machines orfax machines or modems or anything else these devices all have a Ringer Equivalency Number associated with them, the phone company also limites the number of bells (ringer equivalency) on the line.
If the phone company supports 3 bells for example and you connect 2 devices that have a ringer equivalnecy number of 3 that is 6 bells and something is not going to work correctly.
If you can make the answering machine work by itself and you can make the fax feature on the printer work by itself and the problem only shows up when they are connected together then I would think you have either exceeded the number of bells for your line, or Dell has an issue with their feature.
I would suggest as a test if you have in fact tapped off the telephone company line, unplug all of the other phones in the house and just conenct the printer and answer mchine as Dell suggests and see what happens, if it works then you have to decide what phone or phones you are willing to leave unplugged.
Dec 31, 2009 | Dell Photo 964 All-In-One InkJet Printer
Help, call waiting stopped working people sent to answer machine
You have set automatic call diversion to your 'message bank' or answering service when your line is busy for a preset time which may allow you to pick up this second call.
Unless you know the prodecures to change your telephone line options (which may be on the internet or via telephone key pad sequences), talk to your friendly telephone company help desk and ask them to reset your default to what you wish to do.
Hope it helps!
Dec 25, 2009 | Lands Phones
Our AT&T 1725 has quit recognizing when the phone is ringing. The phone keeps own ringing instead of beign answered.
There are a couple of things to try. First is to check the cable & plug that connect the 1725 to the telephone line. Disconnect the phone line from the back of the answering machine, plug it into a known working telephone, using cell phone (or another land line) call the phone number and see if the phone rings.
If it doesn't, replace the line cord and try again.
If it does ring, check the optioning to make sure it is set for, say 2 rings.
Also, is the telephone line a regular telephone company POTS line or is it one that is being provided by a cable modem? If your phone service is being provided by a cable company, the media converter might not be putting out enough voltage for the answering machine to realize that the line is ringing.
If everything is correct, replace the answering machine.
Aug 18, 2009 | AT&T 1725 Answering Machine
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
GE Spacemaker Kitchen Phone/Radio/Answering Machine Model 26976 GE 1
I would pack it and send it to GE for repair replacement as defective
Mar 23, 2017 | GE Spacemaker 26976 Cordless Phone
No fax reception
Send will work on any phone lines
fax machines are often set to only answer 'secondary' ring tones, double triple or higher. When the line was repaired the phone company may have dropped the special tone off your secondary fax line number, fax will not answer without that tone.
Check in the fax answer settings, what the ring tone is, specific instruction on menu settings in your user guide,
Ring your fax line, and check the tone.
If single number fax/phone, check that the fax is set to asnwer all calls then pass on non faxes
Jul 11, 2008 | Brother IntelliFax-2820 Laser Fax
Uniden Cordless Phone Logo
27 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
