My plan jane evcon thermostat is not wired right. The furnace works fine. The air conditioner will only come on when you push the lever up hotter than it is in the room instead of cool. It will then run, but runs and runs and will not shut off. There are 4 wires, red that is hooked to screw with B by it because the blue wire has a piece of paper on it with a Y and is hooked to the Y screw, white that is hooked to one with W and green wire is hooked to the screw with G. little short red wire runs from left to right and then the ground wire is also red. Help me reconfigure this so I can be cool and not blow up my a/c 7670-368/A 65A-753-662 is on inside of cover. This is the thermostat that came in the house; just plan push up or down for temp at top and lever at bottom heat/off/cool. Thanks, Candy candyandzip@yahoo.com
  • candyandzip Aug 07, 2010
    my expert didn't answer after I got him the info he asked for.
  • 43,501 Answers
Okay....two things to check on...
make sure that the terminals and the wires are matched in the t-stat and the furnace board...R-R Y-Y G-G W-W ....if everything matches up then you have a fried t-stat... What you are saying you have in the t-stat should be right... so it has to be one of these other scenario's...
heatman101
Posted on Aug 07, 2010
  • 15,935 Answers
What is the model # of the unit this is controlling??
Thanks!!
Posted on Aug 06, 2010
  • 3 more comments
  • candyandzip Aug 06, 2010
    finally found it
    Coleman Evcon DGATO75BDD
    are you still out there, expert? have any suggestions?
    where did you go expert
    do i have to start over?
Coleman Evcon EB15B heat doesnt stop when it reaches the temp set on the themostat just gets hotter and hotter until I shut it of at the circuit breaker
Thermostat not doing it's job.
Probably the contacts on the thermostat are stuck together, Caused by arcing each time it opens.
If you are up to it.... clean the contacts or replace thermostat,
Cheers
Mar 03, 2015 | Heating & Cooling
Coleman/ Evcon central electric furnace Eb15b thermostat on auto will not blow air out i hear a click u see and feel it heating up then i hear Another click dont see nor feel heat then but put thermostat...
check the thermostat setting on back for electric heat. sounds like it is on gas heat. the fan should turn on right away if it is electric or heat pump.
Nov 15, 2014 | Heating & Cooling
My Coleman Evcon furnace Model EB 12B will start out blowing warm air and then before it reaches the temp set on thermostat starts blowing cold air. We had the thermostat changed over the summer and the...
look at the furnace and turn it on to see if the flames come on. Watch and see if they stay on for a period of time. If they come on then go out you may have a dirty flame sensor, if it goes out and then relights it may be a high limit switch getting weak. hope this helps.
Oct 25, 2013 | Heating & Cooling
This is a colemon evcon electric furnace for mobile home the blower work fine just won't put out no more heat any ideals
when the fan is operating, is the fan switch on the thermostat in "on" or "auto" position? if it\'s in the \'auto\' position, then the stat is calling for heat ok. if so, you should check the safety controls for closure...i.e., the rollout switches (if there are any) and the high limit control, you should also measure the voltage at the gas valve. if you have 22 -27 volts at the gas valve, and you have all upstream gas open, and you have gas available (not shut off by gas company), but still no fire, then you probably have a defective gas valve. otherwise, if you have a wiring diagram, it should be easy to find the problem.
Jan 25, 2013 | Heating & Cooling
I have an Evcon hot surface ignition furnace and can not get the heat to come on .I set my thermostat on desired temp and starts running,but the blower wont come on,on auto I have to switch to the on...
Troubleshooting and Repair
Furnaces with electronic ignition systems may be much more efficient than their early counterparts, but they do it largely through electronics. However, there are still some troubleshooting you can do but fixing the problems can involve replacement of parts more so than repair or adjustment. PROBLEM: Furnace burner will not ignite
Possible Solution
  • With a Hot Surface Ignition (HSI) system, if a gas hissing sound is heard for about 7-10 seconds and the burners do not ignite, the furnace will go into lockout mode.
  • To reset turn the furnace power switch off and back on and try again. The switch is probably located on the side of the furnace. A reset button may also be found on the solid state controller. If resetting fails again, proceed as follows.
  • Turn off power and gas to the furnace
  • Remove and check hot surface igniter being careful not to touch the heat element. If it is cracked or damaged, replace the igniter.
      PROBLEM: Furnace comes on for 7-10 seconds then turns off Possible Solution:
      • Remove flame sensor from its bracket. Lightly clean the surface with fine emery cloth and replace.
      • The problem may also lie in a bad ground or the the black and white wires being reversed (reversed polarity) at the junction box or outlet powering the furnace.
      • The electronic ignition control module must ensure current flow through the flame sensor to ground and if the polarity is reversed in the circuit there is no voltage potential and the flame sensor does not work and closes the gas valve.
      • If the black and white wires are connected correctly and the flame still drops out, then the issue may be a bad ground. Using a volt-ohm meter, measure between the white wire and the ground wire to be sure you have no voltage.
Nov 01, 2010 | Heating & Cooling
My coleman evcon fan motor does not come on. I put the thermostat to on so the fan would run but it will not come on. The rest of the furnace runs properly.
Did you check to see if you have power or fuse blown? If it is a furnace/ air handler and you are comfortable with electricity. Turn
Power off, remove blower door. Find where thermostat wires come into the control board and remove them. If you can find a jumper wire or aligator clips, hook them between R and G. Put blower
door back on and turn on power,
Fan should come on right away, if it does you might have a thermostat problem. If nothing happens but you can hear it hum
or hear nothing at all. Then more than likely the capacitor is bad and or the motor is bad.
Aug 04, 2010 | Coleman Heating & Cooling
Air conditioning runs all the time
I assume this is a manufactured home, this is probably a two transformer system, either your contactor is welded in the on positon or wyou have control wiring issues, (could be the thermostat)
Jul 12, 2009 | Coleman Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
