Question about Sylvania SRC22134 13 in. TV/VCR Combo
I'm just looking for the code to turn set on / off n volume control and or what ever else its able to do with that particular code number , thank you , mike
  • Sylvania Master
  • 3,866 Answers
Here is the code for this brand I hope it does work for you
Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089
This came form a list of codes I have on file let me know ether way or click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 06, 2010
  • andrewselect Aug 06, 2010
    sorry, but forgot to ask how u set up tv in the program mode to accept the coding !
Hello my handsonic 10 has lost volume output on all the pads on kit selection 1 on the (undo) latin perc all other selections onwards to 64 are all ok and have no volume loss at all can you help thanks...
Since the electronics and sensors are ALL the same for ALL the voices, this has to be a setting within the unit. Look for a sensitivity setting in your manual for the unit. Some of these also have a setting for use with sticks that VASTLY affects the sensitivity.
Pay particular attention to "Kit Volume" on page 22 of your user's manual. This affects the volume for different "Kits".
Jan 04, 2011 | Roland HandSonic 10 Percussion Controller
Hi. Can you please tell me the correct code for the Curtis tv for Cablevision Remote? We have two remotes now, the cable remote cannot operate the volume or the power on/off tv, must use Curtis remote.....
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Dec 23, 2010 | Curtis CM13102 13" TV
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
I need a code for my Samsung tv model LE37A456C2DXXU, to connect my Sky remote to the television. Thankyou.
Please rate this solution if you find it helpful. Thanks.
It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says Rev 4, or Rev 6, it might work with this code: 0646
If you have a Rev 8, then try these 3 codes: 1340, 0840 or 0646
Sky's information is a little bit contradictory regarding your particular model of TV, so I don't guarantee success. However, 0840 and 0646 seem to be generic Samsung codes, so I think these would probably control the power and volume functions on you TV if nothing else.
Try the codes above and report back.
Oct 16, 2010 | Samsung TV Set Top Box Remote Control
Looking for universal remote for Dynex brand tv.
I just posted this moments ago:
Well, 'universal' is fundamentally not true anyhow. If your set is newer than the remote, the remote cannot have the complete code set built in and likely no other will either. There are no 'standard' code sets and even if your model was listed, it may not control more than power, volume and channel.
If you want a multibrand/multidevice remote, find one you like, go to the manufacturer's website and check the code list for that particular model number to see if it will be of any use to you before buying it.
NONE of the 'universal' remotes have all the codes sets of all the devices past, present and future. It is a lie and a technical impossibility. ------- While you might find one that can learn to some extent although I have one of those and it won't 'learn' from every other IR remote either.
Oct 17, 2009 | Dynex DX-L42-10A 42 in. LCD TV
I just bought a rca flat panel tv and no universal remote will work
Oct 17, 2009 | RCA Universal Remote Control
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Kenwood stereo control amplifier KC-206 doesn't work
I found this thread when I was having the same problem with mine. Turns out that it's sort of a problem, but not really. Looking at the manual (which I found in another google search) I believe a "4" on the volume level corresponds to a default remote control setting. The remote varies the level between 0 and 10, but the "10" corresponds to the maximum volume setting on the preamp. So it actually works, it's just that the "4" reading doesn't change. There's probably a pin you can short somewhere to make that default to "10" which would be ideal. But I'm not sure where that is. Now on to my other problem. This particular preamp has a subtle 120 Hz hum...
Nov 15, 2008 | JVC RX-E100 5-Channel Amplifier
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Cant program directtv remote to sony tv
I'm not sure of your model number but those remotes use the NEC codes and the variants on the NEC codes. If that code set is not the databse, you may have to "learn" it on your particular remote.
Good luck
Mar 20, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Sylvania SRC22134 13 in. TV/VCR Combo Logo
14 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
