Question about HP Photosmart 2410 All-In-One InkJet Printer
HP Photosmart 2410 will not print cardstock. The paper feeds through but when it goes to print it locks up. Is the paper too thick? Is there a way to adjust the settings?
  • 624 Answers
SOURCE: HP 2410 indicates paper jam
Considering you can get a new Brother laser printer for about $100 and the fact that you current printer is worth about $40 its not worth taking to a repair shop if you can?t fix it yourself. Having said that my first guess would be to take the toner cartridge out and blow the inside clean with some ?compressed air?. Get a can of it from Staples or any computer store for a couple of dollars and resist the urge to use air from a commercial compressor. It?s too strong plus unless you have a water/oil filter you?ll make a mess of your printer. Look carefully at the paper path to ensure a small piece of paper isn?t in there blocking a sensor and if you have another fresh cartridge try that too. I?ve had problems with HP printers doing this and the problem has always been a defective sensor or circuit board. So unless you have a friend or free spare parts you are going to be looking at a repair bill of at least ½ the cost of a low end laser printer.
Posted on Nov 27, 2006
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
  • 406 Answers
SOURCE: Paper Jam when printing on cardstock 2nd run Dell 5110cn
You were using this prevoiously; I mean previously it was fine. now you have problem.
Because usually this may not be the problem with a printer. This is a problem of paper. You may use duplexing if it allows you.
Posted on Mar 24, 2008
  • 20 Answers
SOURCE: My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Posted on Sep 06, 2009
michaelshaun
  • 126 Answers
SOURCE: HP Photosmart D5160 the paper won't feed through
please follow the instructions from the below mentioned URL:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01963794&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3315742
and i hope this should fix the problem for you
please let us know what happened and we will help you further
thanks
regards
Hamid
Posted on Feb 25, 2010
When trying to print business cards they get stuck in the printer and wont move
Just a quick thought here. Check the paper thickness settings to see if you have a cardstock setting. Some printers need the paper thickness to be set to properly work. Also, when the sheet is printing, place you hand on the cardstock and see if you can help it along by pushing slightly. You may feel and see the obstruction. You can find additional information in the user manual under "Print on special and custom-sized media".
May 14, 2015 | HP OfficeJet Office Equipment & Supplies
Why is my printer printing half of page on cardstock
If you are feeding it through like you would with normal weight paper than you are always going to get this. Most printers have a secondary feed point for heavy stock paper. Usually in the back.
Aug 30, 2014 | HP Photosmart C5280 Printer
Cannnot copy a double sided document to cardstock
This is normal. The cardstock is fed from the manual feed or bypass tray and when selected the duplex option goes away. Many manufacturers do this....meaning they do not allow duplexing from the bypass tray. For the same reason they do limit automatic duplexing to standard or near standard papers. Cardstock is specifically excluded from duplexing obviously due to it's thick nature and when duplexing the paper has to be turned over and go thru paper paths that are not suitable for thick paper. If you must make a 2 sided copy using cardstock you will have to run the sheet thru the machine 2 times, also known as manual duplex.
Hope this helps.
Apr 12, 2010 | Copystar - CS-3035 Printer
Cardstock won't feed
You need to hand feed these things.....one at a time. I sometimes find that I have to "help" it a little bit to get it feed by putting just a bit of pressure on the paper to push it into the feeder. Another trick is to make sure the front edge is turned up just a bit. (I usually take about 10-15 pieces of cardstock and roll them, and then feed them one at a time) that seems to work pretty well, too
Jan 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
HP psc 2410 photosmart all-in-one not piking up paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 16, 2009 | HP PSC 2410 All-In-One InkJet Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Paper too thick?
You will need to use the manual feed and insert the cardstock one page at a time. First look at the rear of the printer for a purple dial. Roll the dial downward. This will allow the printer to exit straight out the back of the machine. Allow enough room at the rear of the printer so the cardstock doesn't hit anything on the way out. Next look at the front of the machine at the **** just above the paper tray. You'll see an envelope icon. Align the cardstock when manual feeding one sheet at a time to the left side of the **** next to the envelope icon. When you hit "file, print" select MANUAL FEED in the print window.
The 4L will only do cardstock by one at a time in the way noted above as the feed system isn't strong enough to make the sharp bend coming out of the tray or in the back to bend it around and into the top tray.
Sep 22, 2008 | HP LaserJet 4L Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
HP 2575 Jamming on cardstock paper
most likely that printer would do it if it were brand new, but after a period of time, the mechanism becomes 'tuned' to a certain size paper..
you may need to realign the rollers, etc, to accept the thicker paper.
my recommend..go to a local print shop with paper and images/data on cd, and let them do it.
May 08, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2410 All-In-One InkJet Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
