Question about Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers
We have a SONY DVD Home Theatre system DAV-HDX576WF. It will give us loud sound with FM, the IPod or the DVD, but we cannot get enough volumn from the TV connection. Any suggestions? Thanks.
  • rrabaino Aug 16, 2010
    I responded to the other expert and received no answer. The DVD plays loud. when I switch to the TV the sound goes down. Could it be the Sony TV connection that I plug into is bad? Have you heard of any other situations like this? Thanks.
  • rrabaino Aug 21, 2010
    thank you very much. We plugged in an optical cable and the volumn increased.
  • Sony Master
  • 11,800 Answers
Each device has its own normal level for the signal. Usually they are set at the standardised value - 500mV - but sometimes some devices don't follow the standard. The only thing you can do is to check the connectors and use another cable - bad cables or connector can cause a big drop in signal level. If even after using a new, good quality cable that is a tight fit in the plugs - and these plugs themselves don't move around - then the only thing you can do is to set the maximum volume level higher to partially compensate for  that. You can find this option in the HDMI setup section in the MENU, labeled VOLUME LIMIT..
Posted on Aug 16, 2010
  • 2,272 Answers
Are you using proper wires.If yes then interchange the connections a bit from its ports and check.Also unplug the external wires connected to tv and check the actual volume of tv.Also keep the sound increased in other modes too then switch to tv and check the sounds.Any where the connection is loose or wrong connection. Check- recheck properly. Keep updated.Thanks.
Posted on Aug 06, 2010
  • rrabaino Aug 10, 2010
    I've done all that you mentioned. When I change the function from DVD to TV the sound goes down. This is secondTV that I've had this problem with when connected to the Sony. I'm pretty sure it's the Sony that is the problem. Could it be that the Sony connection that I plug into is faulty? Thanks.
  • raj somaiya
    raj somaiya Aug 17, 2010
    yes very much possible that the Sony connection that you plug into is faulty.As the dvd sound comes proper if directly connected to tv.Get the exact connections from www.radioshack.com.
    some times the connecting wires get weak or are not compatible with the unit and this causes such problems.
    Thanks for keeping updated with your query.
NO SOUND IN THE TV MODE.....
Try pressing the mute button on the remote
Jul 29, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
How can i play my ipod on a dav-dx150 home theatre
there is a wire that pluggs into the headphones spot on our iPod, it then splits into a red/white cable. i dont know where to get this, but mine came with a DVD player
Feb 14, 2009 | Sony DAV-DX150 System
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers Logo
248 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
