Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
I have no picture. Bulb broke, I replaced the Bulb and Ballast??? I'm not sure what else it could be. Thanks Mitch
  • RCA Master
  • 12,061 Answers
Before we can attempt to repair anything at all, there is one thing that one MUST do before anything else is done. Now that is, the making sure that the Power Supply,of the unit, no matter what it is, has the correct Voltages, coming into it, and more importantly, coming OUT of it. This is absolutely imperative, as, IF these Voltages are NOT correct then NOTHING will work, properly at all. So we must measure these voltages with a Volt Meter. All Voltage measurements are made with reference to ground. Meaning we clip, our Black, Minus, Lead onto the Earth, or Chassis, or Negative (-) "Rail" of the Power Supply. Now with the Red lead, we can now, measure these Voltages. Now sometimes, the Voltage of each Output is annotated,or written, onto the PCB, that will indicate the Voltage of that output. However most usually they are NOT, so in this case we MUST have a manual to tell us. Now this manual is called a "Service Manual" or sometimes a "Repair manual" This manual is absolutely vital so much so, that it can be near impossible to do without it. As apart from having "Troubleshooting" step through's, it also has our Voltages. When we measure these Voltages they are 100% EXACT, so IF the Voltage you measure, except for a few rare exceptions, the "Rail" that is NOT at the correct voltage is the one, that the "Fault/Cause" is "ON". Therefore we can now work outwards from the Power Supply, looking for the cause of that problem. Now if the Voltage is Lower than specified, we are invariably looking for a "Short", something has "Faulted" and is "Dragging" the Power Rail down to earth. Now if the "Rail" is "Higher" than the specified Voltage then the fault we are looking for is usually some sort of "Open Circuit" possibly a Diode, or resistor that has changed it's "Value". Now knowing this and knowing that the Power Supply is the FIRST place to start you troubleshooting and repair from. You now have a MUCH better chance of a "Fix". One thing more, DO NOT forget to get your SERVICE MANUAL. for you exact make & model. even if you pay for it, you will be glad you did.
http://www.retrevo.com/support/RCA-HDLP61W151-TVs-manual/id/402ci469/t/2/
Above is your user manual below is your service and repair manual. Another one below to assist in troubleshooting and understanding.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=rca+projection
Below is a tutorial on just how a dlp TV all works, this is what we use to train the engineers to service and understand these units.
http://www.scribd.com/doc/22235534/Hitachi-Training-Manual-Projection-Television-DLP-1
https://www.samswebsite.com/en/photofact/search/index/or/price/os/1/page/904/brand/RCA
Now if you feel that it you do not want to do it. It is my professional advice is to get you set looked at by a RCA Authorised Service Centre, and ask for free "Quote", this way, you will be able to make an informed judgment, as to repair or replace. As these days seemingly insignificant SYMPTOMS, often cost as much to repair as it may cost to buy.
Posted on Aug 06, 2010
I have replaced the bulb and the ballast and still no picture.
Double check your work and make sure you didn't miss something when you replaced the parts.
Feb 09, 2018 | Televison & Video
No picture, sounds fine. Fuse blown
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Jul 29, 2007 | Toshiba 46H84 46" Rear Projection...
I have sound to my t.v, but no picture. bulb is good, i read it could be a ballast?
try to check first if there is a voltage input in to your ballast before replacing it. If there is a current going to your ballast and the bulb still not powering for sure the ballast is defective and you can replace it.
Aug 02, 2011 | RCA Scenium M50WH187 50" HDTV
I had to change my bulb about 6 months ago and now i'm having the same problem. i checked the bulb to make sure it was still intact and indeed it was. i'm wondering if there is some kind of switch to...
Ur tv probally also have the board call the Ballast board is also dead beside the projection lamp was replaced before.This board call the Ballast board job is to help to ignite the projection lamp.About an hour before the Super Bowl.Unplug,replug the tv back about an hour later for the tv for the Ballast board might have some juice left to ignite to light up for projection lamp for the last time to have tv picture to the to watch the Super Bowl.Must replaced the Ballast board.
Feb 05, 2011 | Toshiba 50HM67 50" HDTV
Once again my HLP6163W is not working. When it powers up there is a high pitch whine that sounds like it is a miniature jet engine powering down. The power button does not work, the set just powers up...
well I'm no expert but trying to fix one my self I'd say color wheel due to the noise issue... I have had repair places tel me the wheel and bulb and ballast are problems and if an old ballast is powering up a new bulb the old ballast will prob go out soon. sounds like the tv's are just junk I'm looking for parts so any ballast light or color wheel can be mailed to 25847 melba ave homeland ca 92548 and as I learn more with them good or bad parts I'll surly post it for the good of all so we can keep the land fills empty of the stuff.
Thanks for reading model hlp6163wx/xaa only please.
Aug 17, 2010 | Samsung HLP6163W 61" Rear Projection...
I need to replace the lamp on my hitachi. should i also replace the ballast. thank you
For normal bulb replacement, there should be no need in replacing the ballast. Just be sure to put everything back like it was after changing the bulb. There are interlock switches that must be right for the set to come on. Thanks for using fixya.
Jan 14, 2010 | Hitachi 50UX57B 50" Rear Projection...
Picture flickers on Sony HDTV
Hi,It seems your ballast(board that powers light bulb) is going weak.The ballast was used to provide a lower voltage because lamp didn't use as much as brand new one. A newer one takes more voltage and when ballast doesn't provide as much power it will flicker or produce a dimmer image.I found the one for your tv here: http://www.discount-merchant.com/1091041-KDS-60A3000-p/1091041.htm?Click=48173 Good luck and God bless you!
Jan 06, 2010 | Sony KDS-60A3000 60" HDTV
Replaced the DLP bulb and the picture only worked for ten minutes
Hi,again,Thanks for the blessings.One quick way that works for most sets its to unplug the set wait 5 min and plug it back again.Here's instructions to replace the ballast: http://guides.fixyourdlp.com/samsung/bp47-00033a.php Found ballast here: http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1139281.htm?Click=48173 Pay attention to other sounds like buzzing or whirling because it could also be the color wheel.God bless you and your house! Let me know if you need further help. r2d2repair@gmail.com
Nov 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Ballast Assembly Circuit Board
If that is sparking the ballast is ok. Change the bulb although it looks ok it is not firing up. also make sure the bulb is plugged securely in its socket.
Apr 16, 2008 | Mitsubishi WD-52627 52" Television
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
26 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
