Question about Turboair Heating & Cooling
Unit aill not turn on.new batterys in thr remote, (second set).Also can this unit be run manualy? My model # is TAS12VW/O
  • trt31 Aug 06, 2010
    The unit is a turboair with the # I posted TAS12VW/O if there is another # I dont know where it is.
  • 15,935 Answers
What is the manufacturer of your unit please?
the model # is coming back as invalid.
thanks!
Posted on Aug 06, 2010
    Your reply clearly states that it is a turboair (the brand) the @ I gave you is the only one I can find ,clearly your answer is not satisfactory. Doug.
  • 10,515 Answers
Unfortunately, i am unable to pull up the information regarding the Model number you mentioned.Few of the models in TAS series have a switch. You need to open the air filter cover ( front panel ) on your ac to have an access to that.Other than this, there is no other option as far as i know.
Good Luck!!
Thanks!!
Posted on Aug 07, 2010
I bought a replacement remote for Toshiba TV and it was the same model number CT-90325 same as the original. but it won't operate the TV, does it have to be programmed to the TV somehow?
Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Dec 20, 2016 | Televison & Video
Cannot turn the unit on with the remote
if changing batteries doesn't help, and if pushing down fairly hard on the on/off button doesn't help, then get a new remote. they are pretty cheap. try remotes.com
Aug 25, 2015 | Televison & Video
The remote control does not workand the tv works manualy but the settings are not in order ie channels have not been set correctly,but they cannot be re set manualy
To reset and arrange channels in the order, you must have its remote control. Check whether the remote control emits infrared emission. Check it with fresh batteries. Clean the battery contacts inside it batter compartment. If these contacts have any rust or dust accumulated, there will be no proper battery connection to remote's internal circuits, and won't work well. If all are found OK, check and replace the infrared sensor inside your TV. If you wish to get more details about how to check and replace a remote control, check this link.
Feb 06, 2013 | Samsung Televison & Video
I have a GE Split-Type room air conditioner model number AA1AH24EWI.I used it last summer but now it wont turn on.Have changed the remotes batteries and checked if it is sending signal(looking through digi...
Check power is indoor. And also for long time no use cases, please remove batteries from remote and re fix it when it is on use. Keeping with old batteries for long time with no use will affect the remote. Please check with other remote. It doesn't mean your remote is good, if ultra light flashing thr' camera.
If with other remote, the unit does not start, It's receiving sensor problem. Then you have to repair or replace PCB. Helpful?
Jan 09, 2011 | GE Heating & Cooling
Remote control will not work for my blu ray dvd
Sounds like your DVD players infrared receiving sensor(eye) has gone bad, a rare occurance but I have had that fail in other electronic units before.This would require you to send it in for service but the cost of the repair may justify just replacing the unit. Good luck !
Nov 29, 2009 | Televison & Video
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
I have a split system a/c that the head unit will not respond to the remote. If I turn off the power and restart and I manualy push the button it comes on and blows cool air and then shuts off but I can't...
Replace receiver board or if you have a spare unit try to transfer the receiver board to the defective one and test the remote to confirm the unit problem.
May 28, 2008 | Samsung Heating & Cooling
Does not respond to remote control
After power on the dvd, open the tray and put any video dvd in and close it, wait for about a minute, then press Setup or any button on remote control, if it work then need to replace with the new battery CR2025.
Jan 27, 2008 | Cyberhome DVR 1600 DVD Recorder
Heating & Cooling Logo
173 people viewed this question
Top Turboair Heating & Cooling Experts
Steve F
Thomas Woodburn
Thomas Woodburn
Andy
Are you a Turboair Heating and Cooling Expert? Answer questions, earn points and help others
